1981 power antenna suggestions....
Old 12-31-2017, 05:12 PM
ChevsForever
ChevsForever's Avatar
Default 1981 power antenna suggestions....
I need to replace the antenna assembly. I am looking for feedback on complete units. They range in price from $65 to $175. Thanks!
Old 12-31-2017, 05:27 PM
mikelj
Support Corvetteforum!
mikelj's Avatar
Received 1,389 Likes on 681 Posts
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
I bought the one from Paragon, a genuine GM replacement unit, for my '81. It was plug in easy, and fit perfect if you are replacing an original one. Good luck.
Old 12-31-2017, 05:59 PM
gbvette62
gbvette62's Avatar
Received 2,016 Likes on 1,308 Posts
The reproduction one that lists for $150 (though some vendors do try to sell it for more), is your best bet. Though the motor doesn't look like the original, the parts you see, the mast, nut and tip, all look correct. This antenna is a direct bolt in, using the stock harness and mounting brackets, and is controlled by the radio, just like the OEM one.
You can save some money with the replacement units, but you usually have to adapt the harness and brackets, and not all of them will raise and lower with the radio, like original.
Old 01-01-2018, 10:36 AM
ChevsForever
I apologize for posting this in the wrong section!
Old 01-01-2018, 12:59 PM
garrettb
garrettb's Avatar
I was in the same boat last year. I didn't trust the aftermarket ones, so I found a broken one to rebuild. Usually, it's just the plastic cable inside the mast that is broken. New rebuild kits are available for not a whole lot of money.
LenWoodruff (01-03-2018)
Old 01-01-2018, 10:29 PM
mikelj
mikelj's Avatar
No problem, many of us have C2s and C3s.
Old 01-02-2018, 02:38 AM
doorgunner
Nam Labrat
doorgunner's Avatar
Received 4,153 Likes on 2,726 Posts
Hey....I needed the info.....my basket case needs a new power antenna!
Old 01-02-2018, 08:36 AM
Lakeside49
Lakeside49's Avatar
Replacing the plastic cable is a fairly easy and satisfying DIY project.
Old 01-02-2018, 02:41 PM
larryg3
larryg3's Avatar
after going thru a couple of GM licensed replacement antennas I located an original power antenna out of an early 80's caddy in the junk yard and took the guts out of it and used the original enclosure of my corvette antenna and presto it works..... been fine for the last 3 years and the best of all it looks like the original (because it is) on the outside.
To 1981 power antenna suggestions....
Quick Reply: 1981 power antenna suggestions....
