Belt Tensioner Location 78
Junior member question here... My alternator is not charging and it is assumed to be defective. Where on God's green earth is that tensioner adjuster? By the way, 78 with a ZZ4 350
There's a bolt on the top of the alternator that goes to a bracket. Loosen that bolt, and the bolt underneath the alternator, and use as mentioned above, a breaker bar, or a long screwdriver and pry against the alternator to tighten the belt, then as you're holding the alternator tight, tighten the top bolt to hold it in place. You don't need to pry hard on the alternator, just enough to make the belt tight. Should take less than 5 minutes.
I apologize for not being clear. It was redone I assume, when the ZZ4 was installed, with a serpentine system. It's not the old school with the slotted alternator bracket.
Found it! It's mounted next to the air conditioner compressor, takes a half inch ratchet instead of a 3/8. I had to get underneath it to see it. Problem solved! Thanks for the help
more good news! Turned out to be just a loose connection at the back of the alternator. Tightened it up and she is charging beautifully.
