tri power screen original vs reproduction??
Old 01-14-2018, 08:01 PM
tfringo
tfringo's Avatar
Default tri power screen original vs reproduction??
Hi, are there any identifying features to distinquish a reproduction screen element from original screen element?
I have two that look about the same but one is taller. One might have a slightly smaller mesh. Any opinions out there?
Thanks!
Old 01-14-2018, 08:38 PM
JC68
Support Corvetteforum!
JC68's Avatar
On an original there will be a total of 3 holes visible on the height of the screen. Not 3 complete holes, as the top and bottom holes may not be complete, but 3 holes with all the pieces added up. Reproductions frequently have more holes. There is also a distinctive tooling mark left on the inside rim on originals. See attached pictures.
John
Old 01-14-2018, 08:46 PM
tfringo
tfringo's Avatar
Exactly what I needed. thanks a bunch! Terry
Old 01-14-2018, 10:27 PM
tfringo
tfringo's Avatar
Default Hi, check this out....
I was amazed at the difference between the two. I assume the taller one is reproduction (sad). Shorter one is original based on your assessment.
Have you seen any obvious differences in air cleaner lids? Thanks, Terry
John
Old 01-14-2018, 10:30 PM
tfringo
tfringo's Avatar
If you look at these two. The one on the right in the bottom picture is original. But I was surprised at the difference between the two. Rather cheesy if you ask me.
To tri power screen original vs reproduction??
Quick Reply: tri power screen original vs reproduction??
