70 Center Gauge Surround Removal
Old 02-07-2018, 11:32 AM
fritzh52
fritzh52's Avatar
Default 70 Center Gauge Surround Removal
I've done some searches with no luck. What is the easiest/best way to remove the center gauge surround to change some gauges? No AC. Thanks for any help I don't want to brake anything.
Old 02-07-2018, 11:46 AM
Wee
Wee's Avatar
Try this link.....
https://www.corvetteforum.com/forums...e-removal.html
Brian
Old 02-07-2018, 11:52 AM
Faster Rat
Faster Rat's Avatar
Start by removing the passenger side dash. Then unscrew and remove the wiper control and vent. The radio has to come out to the passenger side, after removing the brace, ***** and disconnect the coax, speakers and power. There are two nuts that hold the gauge panel to the center console. Loosen them enough to slide the panel out. Be careful handling the panel as they will break at the weak side points.
fritzh52 (02-07-2018)
Old 02-07-2018, 11:53 AM
fritzh52
fritzh52's Avatar
Originally Posted by Wee
Thanks Brian, That's just what I was looking for.
Fritz
Old 02-07-2018, 12:09 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi F,
As FR stated.... you REALLY need to be careful handling the bezel.
This is especially true when re-installing it.
The bezel is designed with a very narrow section just above the gauges themselves... the idea being that in the case of a crash a person hitting the center of the dash would break the bezel rather than the bezel putting a 'dent' in the person.
Pushing on the top of the bezel to get it back in place can easily snap it... that's why there are so many broken bezels in cars.
Regards,
Alan
Old 02-07-2018, 07:59 PM
loup68
Support Corvetteforum!
loup68's Avatar
Alan, the 68 Corvette shop manual has NO mention about the delicate bezel. My clock died and snap! The 69 shop manual has BOLD lettering about how fragile the bezel is!!! Too late for me. Lou.
To 70 Center Gauge Surround Removal
Quick Reply: 70 Center Gauge Surround Removal
