Could this be a simple heater problem on a 1980?
Old 03-05-2018, 01:43 PM
yelo80vette
yelo80vette's Avatar
Default Could this be a simple heater problem on a 1980?
I recently lost heat in my 1980 L48. There is no typical evidence of a bad or leaking heater core. Plus I'm almost sure it isn't the vent doors. Has anyone else had a problem like this... or possibly know of a solution?
Old 03-05-2018, 02:15 PM
henrikse
henrikse's Avatar
Is it blowing cold air? If so the vacuum to the door that controls?
yelo80vette (03-05-2018)
Old 03-05-2018, 02:17 PM
ntfday
ntfday's Avatar
My only thought is a faulty heater control valve unless of course the water pump went south, but you'd know that from a major overheating problem.
Old 03-05-2018, 02:21 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by yelo80vette
...possibly know of a solution...
Check the hot water control valve under the hood. It may be stuck closed.
Old 03-05-2018, 02:46 PM
SwampeastMike
SwampeastMike's Avatar
It's on the passenger side of the engine compartment ahead of the blower box and A/C accumulator. It has two heater hose connections and one very small vacuum line leading through the firewall.
Old 03-05-2018, 09:58 PM
yelo80vette
Yes. The air coming out now is, well, not cold particularly. It's pretty much whatever the outside temperature is.
Old 03-05-2018, 10:21 PM
76bomb
76bomb's Avatar
Basic question... is the coolant level low?
yelo80vette (03-06-2018)
Old 03-05-2018, 11:28 PM
ntfday
ntfday's Avatar
Have the heater hoses been replaced? If so with the proper hoses? The hoses are preformed and if regular hose is used they could collapse cutting off the water to the heater core. If the coolant was low enough that you're not getting any heat then you would have a MAJOR overheating problem. As I said earlier you problem,IMHO, lies in either the hoses or the heater control valve. BTW, these are the hose you should have,
https://www.ebay.com/itm/1968-1982-C...tTjkAJ&vxp=mtr
Old 03-06-2018, 12:03 AM
yelo80vette
Nope. Fresh antifreeze always kept at the proper level.
Old 03-06-2018, 12:07 AM
yelo80vette
Nope. I've never replaced the heater hoses since I've had it and they're still in good shape. I believe I'll probably begin my investigation at the heater control valve. Thanks for the link !
Old 03-06-2018, 12:21 AM
ntfday
ntfday's Avatar
This should be what you're looking for, be sure you're getting vacuum to the valve.
https://www.ebay.com/itm/HVAC-Heater...JafLde&vxp=mtr
Old 03-06-2018, 02:01 AM
yelo80vette
Ah ha. Great. Thanks for the lead.
To Could this be a simple heater problem on a 1980?
Quick Reply: Could this be a simple heater problem on a 1980?
