Wiper door assembly spring
I am rebuilding the wiper system and have a question about the spring on the wiper door assembly. The spring that runs on the rod articulates the system somehow. The movement seems to be frozen as when I move it in the vice (gently) it doesn’t return with the spring pressure. How do I fix? Is it shot? I hope I don’t have to take it all apart as that requires rivet work.
Received 2,878 Likes
Hi A,
Does cycling the rod that connects to the vacuum actuator move the door mechanism?
You need to hold the brackets that attach the mechanism to the firewall steady in order to see if the door pivots are moved when you cycle the rod.
If it does, then the mechanism and spring are free enough to be used.
Regards,
Alan
Regards,
Alan
Akroland (03-13-2018)
