1981 starter wiring
1981 starter wiring
I HAVE A 1981 CORVETTE , Someone broke the plugs that connects the wires from firewall to starter plug base wires , Can anyone help me figure this wiring mess up ?
The blue and black wires connected to the plug are for your electric fan. Those plug into the sensor in the block. Black gets grounded, and the purple/red wires go to your starter solenoid. I wish I had a photo. Maybe someone else has one.
Kevin Ramey (05-04-2018)
also I need to run the wires from base A (firewall harness) in picture to base B (starter harness) do you know any these ? the base A was broken and all the wires just came out the plug so I have to rerun all straight into base B
I was able to find a picture that may help. Full disclosure, it was taken before I detailed and cleaned this area, but you still get the gist of how things are connected. The black wire with the large terminal on it gets grounded through one of your bell housing bolts.
Yes, the connector commonly melts due to the high current that must pass through it. When I redid mine, I eliminated the connector, and soldered the wires together. Problem solved!
big help
Updated
if its right I still don't know where to put black wire and 2 red wires and the purple all coming from the firewall ,, any ideals ?
The red wire goes onto the r has no connection unless using a coil and the purple goes to the s
