More Gas
More Gas
So I'm going to replace the gas tank on my 71' as part of my on-going restoration.
I believe my the tank capacity for these years is 18 gallons, will a later model 78-82 24 gallon tank fit? Has anyone done this or even tried?
I already removed my spare tire and will be switching to ride tech in the near future so no concerns if it takes up a little more space underneath.
No I don't car about it not being the right tank for that year, but I do car about getting an extra 6 gallons if possible.
thanks for any feed back
In 78 they changed to the greenhouse rear window which allowed more space for a larger tank.
I don't see how you will have enough vertical room for the larger tank.
I would research what early c3 race cars have for fuel cells...you can probably find something bigger...unless they cut into the back to get more room....
https://www.corvetteforum.com/forums...-capacity.html
seans85vette (05-08-2018)
Received 1,469 Likes
Cruise-In II Veteran
