C3- 1982 wiring diagram required
Hi, need a wiring diagram for a C3 1982 model vette. I'm being fleeced by an auto electrician whose ..using the force... pls help. diversteve@xtra.co.nz
I hope you sort it
You may next some help on the NSW corvette forum
https://nswcorvettes.com.au/forum/
There is a few members with lots of electrical know how
trying to put together a 79 console area and have one bulb that I don’t know where it goes. One black wire and one gray. Sits right next to manual shifter. Looks like a general illumination bulb. Any suggestions? OK after looking at the wiring diagram it appears as though the bulb illuminates the PRNDL on a automatic transmission car. What do we do with a 4 speed car while installing a new console top including a new shift pattern? I see no spot to click the bulb to the bottom of the console. Much thanks to the gurus
3 yr old post. But the bulb is for the automatic indicator illumination. 💡
just part of the general wiring harness. leave the bulb out.
Schematics show a bulb for A/T only. Someone over the years may have installed one.
Remove the bulb and elect. tape the socket. Shouldn’t cause any problems.
