Exterior Door Handle Flap not Flush or Level
Good Afternoon All,
The driver's side exterior door handle flap on my 1970 Corvette no longer springs back into place. In fact, after comparing it to the passenger side, which works fine, I can see that the small spring that is visible as soon as the flap is depressed is disconnected or broken (not under any tension whatsoever, unlike the passenger side). You can see the spring in my photo below.
My question is, am I able to just disassemble the door handle and replace that spring, or do I need a whole new handle? Please let me know the pros and cons of replacing the door handle vs repair.
Note: I did a forum search and found that the people who had a similar problem, also had a door that was difficult to open. My door opens with no problem.
Thanks!
Thanks!
Just another Corvette guy
If you don't want to spend the $45 for a new outer handle, and all the work involved they make a repair spring kit for about $13 (probably even cheaper on eBay). They work fine too.
https://www.ecklerscorvette.com/corv...1969-1982.html
Probably, but if you're going to remove a 48 year old pot metal handle, at that point it's just easier to install a brand new one.
Greg
Greg
Dang,
I just dug through my odds and ends. I knew I had a good used handle. Turns out it's a passenger side, sorry. I would have given it to you rather than just let it collect dust around here.
Check out the repair stainless steel spring kit a bit closer. Part # DR-307 in the Zip Catalog for $8.95. It is honestly a 15-second repair and the door handle flap looks and operates as normal. I installed one a few years ago and have been very pleased with the result.
To replace spring correctly looks like right angle grinder grind off riveted end of pin. Drive pin out. Replace spring. Epoxy pin back In.
Received 2,878 Likes
Hi ZRX,
I'm unsure if new springs for the flapper are available... so it might require removing one from another handle if you attempt to replace the original.
If you decide to replace the handle do some homework on why they're available at several prices.
Regards,
Alan
Regards,
Alan
Total repair time is 15 seconds! You do not have to remove the handle. The repair part is a flat stainless "L" shaped piece that you squeeze and slide over the rod in the handle. I know it sounds "flaky", but it works great and is not noticed once installed. I was skeptical when I ordered the part, but am very satisfied with the results. BTW, I have a NOS handle to replace the one with the broken spring, but after installing the flat spring repair part I won't try to remove the original handle and risk scratching the paint, etc.
Jim
Jim
Jim
^^^THIS^^^
I installed the door handle flap spring 5 years ago and it works great. It was probably the easiest repair I've ever made to my Corvette.
Jim
Jim
Again, very intriguing. In the 5 years since installing it, has the door handle seen a lot of use? Where did you get yours? If it's not expensive, it might make sense to try it. Even if it didn't last as long as yours (and The Hot Rod Grill's) and required handle replacement, it really wouldn't matter as I would have to remove the original handle either way.
Part # DR-307 in the Zip Catalog for $8.95. It's been used every time I have gotten into the car in the last few years. No problems and I would do it again rather than installing the NOS handle that I have.
