Best tire size for a 69, 17 or 18 inch?
One question I have is, how much of a pain is it to relocated the Parking brake bracket? I am rebuilding the parking brake this weekend anyway.
Fairly simple, use cutoff wheel to remove then reattach to calbe and locate on top of trailing arm and weld on. T
gleninsandiego (05-26-2018)
Glenn
One site you may find of great value (well I did at least) is
https://www.rimsntires.com/specspro.jsp
This page will allow you to put in the specs of the original 15" wheel and tyre set then the possible new wheel and tyre options.
It will then show you how much closer it is to guard, suspension etc etc.
Craig
Craig
I am using 18” Wheels front 18x8 rear 18x9.5 255 45 18. 2” adapters all around no problem with the rear. There is rubbing in the front it rubs to the frame and a little on the sway bar. The offset is 40 and the back spacing is 6.020.
I am changing the tires to 235/45/18
and changing the adapters to 60 mm
pleas check
https://www.corvetteforum.com/forums...ch-wheels.html
pleas check
Glenn
Craig
Craig
I am still trying to figure out why most guys are running 245's up front and not 255's based on this. Is it because they are running a different backspace tire or wheel width?
Glenn
C3 of Year Finalist (track prepared) 2019
Posted this previously in this thread: https://www.corvetteforum.com/forums...post1592624772
Here is some pics of my arms with handbrake cable relocated for comparison.
Modified above, standard below:
Clearance to tyre (255/50r17 on 17x9.5, 5.05" backspace). You can clearly see here how a smaller diameter wheel would be closer to the trailing arm:
Brake line and cable routing:
Hope that helps.
Hope that helps.
Well here is the plan
I have a torque thrust II that I have had for awhile that is 17 inch
I ordered a 255/45 17 tire
It should arrive at the tire dealer tomorrow morning where they will mount the tire on my wheel.
Then I am going to test fit it to the front of my 69 to see if it rubs
If it doesn't I will get a set of 255's
If it does rub, I will get the 245 / 45 17 for up front
and use the 255's in the rear
They are having a good sale tomorrow and saturday at the tire store.
#33
Just keep in mind you need to be happy with clearance at the current and possibly future lower height If your going to lower the Vette to remove the gaps.
#34
For what its worth,
I just got my new wheels on.
Front: 18x8 4.5" backspace with 245/45x18 tires
Back: 18x9.5 with 5.25" backspace with 275/40x18
I used a 1/4" spacer in the back to clear my oversized anti-sway bar. No spacer in front. I DID have to cut off and relocate the parking brake mount.
They are AWESOME!!!!!!
The following 2 users liked this post by scottjamison:
ariba (06-28-2018),
#35
I got the 255/45 17 placed on my wheel today and placed it on the front of my 69. Everything barely cleared...as the car sat without the engine in it.
But it appeared to me that as the body would move down with the engine weight, there was the potential for rubbing, if ever so slight.
So I decided with this set of wheels and tires being as cheap as they were (I got a Memorial Day sale deal) I would play it safe for now.
I ordered the 245/50 15 for up front and will use the 255's in the back
Right now I have absolutely no drivable wheels and tires so this will be the base to get the car running and driving.
Thanks for all the advice
Glenn in San Diego
#36
I realize this has been a few years, but what offset are the 19-inch rims, I'm looking to do the same size tires on my 70
#37
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,324 Likes
Rescue Rogers (01-22-2023)
