Ask Willcox A Question Here and Hopefully others will respond.
Premium Supporting Vendor
Thanked 1,282 Times
in
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Can you take and post a picture of this? I'm out of town until Tuesday.....
I found the info I was looking for on page L340 in the aim. I was thinking it was for some sort of option so I paged through the option sections of the aim and found it. the p.o. must have removed the 2 a/c relays and jumpered out the compressor clutch start circuit. I am thinking with out the relays full compressor clutch current is now across the console switch and that is not real good.i see the blocking relay is still available but the diesel relay with the timed coil is going to be hard to find.thanks for responding as I am sure I will have more questions for you. bnb
Thanked 1,282 Times
in
CF Senior Member
Hi Ernie
I know that a while back you were working on a wiper delay timer mod for 68 to 72 cars (with wiper door covers). Is this still on the back burner or are we looking at a dead issue here?
Thanks in advance.
Thanks in advance.
CF Senior Member
Are all of the intermittent wiper switches for an '81 made by the same company. If not who offers the best quality? These are are pain to change out. I want to make sure I have a good one this go around.
Thanked 1,282 Times
in
Rebuild your old switch is always my answer in our shop.... it's really not that hard it just takes time and patience. If you follow the three guides below it'll walk you through the process of rebuilding, testing it and rebuilding the pot that controls the delay.
Ernie
1978-1982 Corvette Windshield Wiper Switch Repair
1978-1982 Corvette Wiper Switch Testing W/pulse Wipers
1978-1982 Corvette Wiper Switch Rebuilding, How to get to the delay potentiometer and where to clean.
And lastly... while you have it apart, replace the decal. https://willcoxcorvette.com/wiper-sw...ecal-1978-1991
Willcox
Thanked 1,282 Times
in
Please, Please, Please...
I'm not in sales and if you have a sale or order question please direct an email to [email protected] or [email protected] If you have a sale question please post it in the current sale thread, this is a tech help and answer thread only.
Ernie
TheCorvetteBen
What a great thread. Another reason why I usually order from Willcox and pass on the other vendors!
Thanked 1,282 Times
in
I just replaced my glass t-tops with a fiberglass set on my '81. I replaced the ws on both. The window in and out fits great I have a slight gap at the front top horizontal edge.
Do I have to readjust my window to fit the new tops?
Why would it be so different from the way the glass tops seal?
Craig
Craig
I missed answering you I'm sorry, it got buried while I was trying to fix the internet issue I was having.
The t-top weatherstrips are adjustable in the section that is over your head and if they are new (or used) you may need to adjust this.
You may want to loosen the screws and try to adjust it to meat the glass.
When you install T-Top weatherstrips you never glue then under the section over your head until you have adjusted them. Once you adjust them to meet the glass you use painters tape (or masking) and mark the edge of the weatherstrip. Then apply glue to the weatherstrip, glue to the top and allow to dry... Then apply a thin bead of glue to the weatherstrip, line it up with the tape and attach the screws.
Willcox
1970-1982 T-Top Weatherstrip Installation.
@ Dave
Dave, I don't think it can be one, which is not a big deal... I don't sponsor this thread and if someone else is, it cannot be a sticky... No worries, it's keeping me hopping.
Ernie
CF Senior Member
Ernie,
I just finished adjusting the fiberglass tops this morning. It took playing with a bunch of shims in different positions to get it right.
I watched your video at least three times. That helped me quite a bit. The Melrose Top adjustment video helped also.
I can see that I'm going to have to adjust the up stops on the door glass on the driver side due to a slight gap.
I used 3m strip caulk under the outside portion of the weather strips. I figured I would always be able to adjust it if needed. Is this going to be a problem?
#33
Thanked 1,282 Times
in
Ernie,
Ernie
#34
Thanked 1,282 Times
in
#35
Thanked 1,282 Times
in
I'm sorry I missed your postl.... It's not on the back burner, it's just not on the front burner. In the last year we've came out with about 100 new parts and they were way easier on us than the development of this module. The issue is the timer. While aftermarket kits are available, the original GM delay modules used a sweep timer to tell the system the position of the wiper arms to keep them in time. I don't want to make a generic kit, that's too easy. On the 1978-1982 cars the wiper cover had a resistor on it that the bell crank inside the motor hit on every sweep. This told the control module the exact position of the arms.... this has proven difficult and something I should revisit soon.
I posted a picture below of how the 1978-1982 kept track of the wiper arm position. I'll talk with Bobby on Monday and see if he's made any progress on this. What is nice is that we now have access to a 3d printer which might make printing these covers with the time resistor added... I'm just not sure. It's still on the board, I'm just not sure where we are on this to be honest.
Ernie
#36
Thanked 1,282 Times
in
No questions since the 7th? lol... just checking in.
#37
CF Senior Member
Does your $455 full weatherstrip kit include window felts? I received my kit the other day for my 68, just wondering if I need to order the felts separate and which part number it is on the website
#38
Thanked 1,282 Times
in
The felts are not included in the weatherstripping kits, I'm sorry. Door felts can be found at this link https://willcoxcorvette.com/catalogs...18&q=door+felt
However, if you are wanting just the felts, they are listed as well as the inner assemblies with the rubber wipe.
68 felts are tricky for sure.... because the inner wipes had a rubber wipe that trimmed out the door panel and was smashed between the wipe and the wipe retainer.
You can see some good examples of how this installed at this link http://repairs.willcoxcorvette.com/1...d-rubber-wipe/
