distributor
Old Jun 5, 2018 | 07:35 AM
pigfarmer's Avatar
pigfarmer
Default distributor
I have a ’69 350/350 and have a couple of questions regarding a small project.
I want to pull my original 1111493 distributor and rebuild it but still want a running car while I do so. I am looking for a temporary replacement. I will be keeping the coil, points etc. Not looking to change.
Now that I have been looking reality has hit me and I see that used GM mechanical tach drives are pricey and have been thinking that I can do without the tach drive. Around here I can find an old non-tach drive dist for about $20.
So here’s my questions:
Are all SBC distributors backwards compatible with or without the tach drive? I have seen several online which are late ‘50s and early ‘60s and have been wondering. Generally, I think the answer is yes with maybe a few exceptions but if I knew the answer I wouldn’t be asking. I realize there are difference with weights, springs etc that will affect the advance curve- I'm talking about drop in fit and use, not necessarily top performance.
I have checked out the For Sale section of this forum and I also check the usual online haunts. Not in a hurry. Just thought I’d throw this out – looking for a ‘mule’ to learn how to do the rebuild. Maybe someone’s got something useful propping open the garage door or something ….
Old Jun 5, 2018 | 09:00 AM
ezobens's Avatar
ezobens
All SBC points distributors are identical dimensionally and will drop right in.
Old Jun 5, 2018 | 09:51 AM
TimAT's Avatar
TimAT
With very few exceptions, BBC and SBC distributors are all the same as far as interchange.
Old Jun 6, 2018 | 12:27 AM
Giddy-up Go's Avatar
Giddy-up Go
Until you get to more modern HEI. Then they are different. Don't ask how I know.
To distributor
