78 issues
I appreciate any help/advice you care to offer.
No disrespect, vdavenp802, but there is no guarantee any Pace Car you find is going to be perfect. If you're not familiar with C3s in general and Pace Cars specifically, you may want to consider taking someone with you who knows these cars when you look at potential purchases.
Have you read the 10 Rules?
https://www.corvetteforum.com/forums...-corvette.html
Don't be surprised is if the power steering cylinder is leaking. If the clock is working, it most likely is not original, or has been upgraded to quartz movement. When I got my 78 (not a pace) all the dash light were out, the circuit board behind the center console was fried. Learned real fast to be patient when taking apart the dash cluster. Anyway, you should expect to have problems on a 40 years car unless it was cared for well.
Good Luck, Bill
PS, if you purchase a C3, invest in the GM service manual and the AIM.
Replacing the rear wheel bearings is not easy or cheap in the grand scheme of things and a large number of C3's need them replaced.
The window and lock mechanisms in the doors gum up and get VERY stiff--the only true solution is to completely disassemble, clean and lubricate the mechanisms replacing parts as needed. The window assist spring on the power windows frequently breaks--you'll know it's broken if the window zooms down and creeps up. If the windows operate smoothly and quickly and the power locks (if equipped) work and the key locks turn easily you can fairly assume that the mechanisms have been serviced.
The alarm arming switch that is attached to the driver door lock frequently fails causing the alarm to sound continuously. The alarm system was standard. The common "solution" is to disconnect the dedicated alarm horn. Unfortunately this means that the essentially eternal alarm relay in the center console is constantly energized thus draining the battery. This is a VERY common reason that the "ACC" (accessory) fuse is removed thus killing the interior courtesy lights, power locks, power antenna, clock, lighter and horn.
Problems in the ACC circuit that cause a short circuit or battery drain are common. Besides the above mentioned alarm problem, the electronic module that controls the courtesy light delay as well as aftermarket additions and poor attempts to fix problems are frequent culprits. An installed ACC fuse with everything it controls working with a lively starter AFTER an overnight sit is an excellent indicator of a well-maintained car.
The plastic laminated printed circuits for the cluster and gauge pack delaminate, short out and cause fuses to blow and gauges/indicator lamps to not work.
The simply (and poorly) designed body grounds corrode even on low mileage cars that have seen very little wet weather. These cause all manner of problems to include dim headlamps, bizarre blinker/hazard/brake light operation, poor/noisy HVAC blower performance, erratic gauge operation, etc., etc.
The choke on the carburetor is often sticky and/or improperly adjusted resulting in very difficult cold engine starts. Per the instructions and with a cold engine press the pedal (slowly) to the floor and release (slowly). Repeat. With foot OFF the gas, rank for no more than 30 seconds. If it fails to start repeat the steps. If everything is perfect the carb will be at high idle and you wait about 30 seconds before putting into gear and using the gas pedal.
Vacuum problems are common. Many are nothing more than old hoses that need to be replaced. These cars are FILLED with vacuum hoses and even if the look/test good their ends are often stretched. Entire replacement sets for every system are available. The headlight vacuum motors and relays, while long lasting, are not eternal. Unfortunately the available replacements are of poor quality.
Same. Small block Chevrolet 350CID can last the life of the car.
Probably not a single "something", but all these cars can share common issues.
This is exactly why I posted here to get 'some' idea of what to look for. Not looking fro perfect. Realizing the cars are 40 years old now, and if I'm looking at a 26K car and knowing at 30K the rear end goes(or trailing arms), would be of interest to me.
I appreciate your help, thanks.
http://hunt4cleanair.net/Articles/buyingright.pdf
Good Luck, Bill
