Barn finds. what do I have here
Hi everyone!
New to the forum, because I stumbled across some stuff, and I need some help. I do a lot of property management, and I walked through a warehouse where someone was storing cars here. As a car enthusiast I immediately started checking them out, but since I haven't done a lot of work with corvettes I thought I would come to the pros and let me know what my options are.
The red car appears to be an 81 based on a the (79L) paint and (12C)trim codes I found. I didn't get a chance to get a vin number. The black one I believe is somewhere around a 70 based on the rear window, but I haven't been able to confirm.
My question is.... can these 2 cars be put together? Red one has the engine and driveline, but someone hacked the roof, and rear end off it. Can the black rear end be molded onto the red one or vice versa?
Theres no interior in either one, but I think I have all the body pieces, and driveline if what im thinking is possible. Im not sure how interchangeable parts are on these, so any help would be appreciated.
This will certainly be a big project, but Ive always liked this body style, so even if its not worth anything when im done it could be fun to drive, and at least it would have a story.
Thanks in advance
Ian
Thanks in advance
Ian
Just another Corvette guy
I think the black one is a 1968 by looking at the door push button and the lack of flares on the rear fenders. The red one is scrap unless the frame is good and someone needs a frame. The black one probably could be salvaged, depending upon what you have for it but, that would be a HUGE project.
Hi Ian,
First post!! Welcome to the forum. The two cars you found are not compatible. Someone probably found out the hard way and abandoned the build. Unfortunate. The early car is certainly interesting, but needs so much I am afraid its a lost cause. parts cars at best.
Ray
Ray
Received 1,469 Likes
Cruise-In II Veteran
Just curious, but isn't that a law enforcement officer in the background of the first pic? Are these two cars stolen?
The '68 should be easily sale-able in its current condition as a complete rear clip, without too much problem. Provided it's not rusty.
Put it on eBay and it will sell. The later body is scrap.
Does the black one still have it's trim tag and/or VIN tag attached?
only the left side shows. is the right side of the black body in similar shape as the left? is the whole nose ok? if so, once removed from the body, that nose and hood are somewhere in the 200-600 range for nose and 1-200 for the hood. then if you feel adventurous cut the 8 body bolts and toss that body in a dumpster. now you can see the frame and drivetrain and a guesstimat if any value, or 5 cents a pound... large parts, what state?
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Nice Find
I love it when someone discovers cars like you have done. The intrigue and mystery of what they are, where they came from, and what to do with them can all be fascinating for readers here on the CF. Please do continue to post and because you mention sales soon, read the stickies on selling here on the forum so you can be familiar with what you can, and cannot do with those cars here. Also, please consider filing out your profile so we have a clue where you are located. Guys near you would gladly help you assess those cars and give you some good advice on them as well. Lots of knowledge here on the forum. Best of success to you and please let me know if I can be of assistance.
Best regards,
David Howard
AllVettes4Me
Best regards,
David Howard
AllVettes4Me
The other side of the black one is in similar condition to the one pictured. No nose though.
The red car (minus the butchered roof and interior) is complete. Doors, motor, driveline, etc.
So........... I have fairly extensive background in bodywork and fabricating. My adhd/ocd has been in full swing since my original post and if possible, can anyone give me specifics as to why I couldn't mount the black rear clip onto the red frame. Are the frames different in length/width. Would the wheelbase be the same? I am able to move body mounts as needed. Any specifics of fenders to A pillar heights and rockers?
in theory there's only a few penetrations into the actual cab right? Steering column, shift lever, throttle cable, wiring harness.... Sure I'm missing something, but they should be able to be corrected with a few "adjustments"
in other words. Could I spend a weekend doing some grafting and make this thing look decent. I'm not looking for a concours car, but I think with a decent paint job the 2 body styles would mesh well given the heights and widths are similar.
this sounds like a fun adventure so talk me out of it by telling me my fenders will stick out 3" from my doors or something along those lines because I won't create an atrocity like that. I just want a t-top to drive around on nice days with the wife.
There's quite a lot of differences in the rear part of the frame between the black and red car. You could modify all the rear bumper brackets to make it work, its not an insignificant amount of work but having done most of it on my own 79 its probably not going to be that big a deal for someone like you with an extensive background in bodywork and fabricating. Ultimately you end up with an 80-82 front end, 68-73 rear end, it would be one of a kind and personally I wonder how well the two different styles would appear together. You'd have the 78-82 interior (which in my opinion is much nicer looking than the older C3 interior) and the entire combination I think would likely be worth a lot less than you'd put into making this all one car but on the other hand, almost every restoration results in a car that's worth a lot less than you put into it. If you're looking to keep it for yourself and you like all this stuff together maybe its worth doing. If you're hoping to sell it when done, don't waste your time and money, just sell what you've got as is.
Here is where I started to modify my 68-73 rear bumper brackets to fit on the 79 frame to give you some idea of what's involved:
https://www.corvetteforum.com/forums...post1594867310
Senior Member
St. Jude Donor '10
Good luck with your decisions.
David Howard
AllVettes4Me
I believe the 68 body will sit right on the same mounts. Then you will have a body, frame of unknown-so far-condition, a nose that doesn't match the body, and a motor-trans of completely unknown condition. No rear, trim, lights, interior, bumpers, TITLE! ... Sell. The. Parts...
mark me down as the dumbest chop shop owner than...
www.Skidmarkracing.Net
We build some serious vintage BMW's and thought I'd try my hand at piecing some vettes together that are collectively viewed as trash or worth nothing. A modified unpure corvette is better than sending them to the scrap yard which is where the owners of the building want them.
If you go get a bomb vette with decent interior for all the little missing stuff, this is possible. But, since it is a chrome bumper rear body, you should scare up a 68-72 nose. Then you need 68-72 bumpers too. There is just so much missing. Including the title.
