Temperature gauge issuest
Hi guys,
I have a 79 L82 four speed with factory a/c, good radiator, new coolant, newish 180 degree thermostat. The factory electric fan does work but I'm not sure that it works with the a/c not working -it has a gas leak somewhere that I need to fix. My problem is that when running on the highway in air temp of about 55 degrees my temp gauge shows just below 220 most of the time but then climbs right to the top of the red zone, stays there for maybe 10 or 15 seconds and then quickly drops back to normal again. It stays at normal for a short while and then does it again, back to the red zone. I've checked both radiator hoses (new) and the t stat with my I/ r gauge and the engine does not get that hot. Would the cause be the sender unit or the gauge or the resistor on the back of the gauge or maybe wiring? Also is the sender in the rear on the passenger side? There is another sender in the drivers side towards the front but I don't know what that one is for .
Help? Cheers.
Help? Cheers.
Hi guys,
Help? Cheers.
Help? Cheers.
Is this the stock temperature gage you are talking about? If the engine is not overheating, gage or sending unit might be bad or not correctly paired to the gage. The green wire is for the factory gage, it is connected to the temperature sending unit on the driver side head. The other sending unit might be for the fans, did you install the fans? Pretty confusing st this point. Pictures of fan wiring might help.
1979L824speed (07-04-2018)
The sending unit towards the rear of the passenger head is for the electric fan, and as stated, the sender in the driver's head with the green wire is for the gauge. I'd start with that sender, as it's the easiest to do, and not that expensive. As a comparison, my 79 L-82 runs just under the 220 mark on the highway in the summer time by the factory gauge.
Thanks for your help.
anytime you have temperature problems the first thing to check is the accuracy of the gauge.
to do this at home, I remove the sending unit, connect with jumper wires and Long extension cord to the car.
put sending unit in pan of water, bring to a boil, your gauge should read 212 F.
if not you have the wrong sending unit. do not forget to connect ground to the sending unit.
after you know your gauge is accurate, you can go chase real temperature problems.
running 220 is too hot, a typical symptom of Air in cooling system.
a properly functioning cooling system should not climb more than app. 10 degrees beyond your thermostat rating.
That’s a great idea. I’ll do that as soon as I get the replacement sender unit. I’ll test them both just as a check.
I had wondered about air in the system and also about whether the water pump might not be pumping enough water through the engine. The pump is quiet so I don’t think that’s the problem. Last time I replaced the coolant I jacked the right front of the car up as high as I could to get as much air out as possible but with the radiator cap not being on top of the radiator it seems impossible to get all the air out. Unless there’s another way that I don’t know about.
Is the air dam installed?
check your coolant thermostat the same way in hot water, it should open at 160 or 180 degrees.
OK, got the new sender unit in the mail, hooked to up with a couple of leads to the ground and the wire to the cars gauge, dropped it in the pot and boiled the water.
The gauge quite quickly went right up the top of the red zone.
I'm guessing that means the gauge is faulty because it certainly wasn't 280 degrees in the pot, only 212.
i know Wilcox makes a new resistor for the back of the gauge. Do you think that might be the problem?
Thanks.
Thanks.
Thanks.
Thanks.
New wrong sending unit for that gauge.
go to Wilcox corvette, for details and correct sending unit.
my clock doesn't work either so I'll try to fix that as well when it's out.
Thanks.
Almost everything on my car is as original and I think the gauge is. I'll check the condition of the back of it when I get it apart in about two weeks.
Thanks.
I don't know how to make it any clearer, they gave you what they thought is the correct part, with the correct resistance.
IT IS NOT. ... the sending unit resistance must be matched with the correct gauge.
( this happens all the time, i need a sender unit for 19xx corvette,
parts guy punches computer and hands you a sending unit, it looks right but it does not have the correct resistance.)
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The new senders are goofy, you can replace the resistor in a factory gauge and with an IR gun dial in the temperature on the gauge. This works great and especially with you knowing what temp the thermostat opens at.... So in theory, you could feel the upper hose, then dial the gauge to 185. (aprox). None of the new replacement or reproduction senders read correctly and if you do get one that does you are one of the lucky people walking this earth. At this link you'll find a lot of info on the 1979 temperature gauges. http://repairs.willcoxcorvette.com/?yt=1979&s=temp
https://youtu.be/WCERae6nJGQ
Thanks.
With my gauge reading normal, I.e just below 220 most of the time but often going briefly to 280, does that indicate to you that the rheostat on the back of the gauge is failing? If that is the case I'll order one of your adjustable ones but first I have to remove the gauge to see if it's original or not and I won't get time to do that for a couple of weeks.
Thanks.
Might have to get the adjustable rheostat from Wilcox.
You must first determine/verify the correct resistance for your gauge, use an 80 Ohm resistor, in place of your sensor.
If your gauge goes to app. 212 you have your resistance number correct. then order one of the 80 Ohm sending units below.
I used boiling water , 212 degrees as a base for testing the senders (the gauge is marked at 210 so that is almost perfect).
Most stock C3 gauges when inputted with 79-82 Ohms will read right around 212.
So if you put a sender in boiling water it needs to have an ohms reading of 79-82 ohms to make the gauge read 212.
The best and closest senders I've found are the ones from Advanced and O-Rileys both from BWD #WT203 at $6 each. O-Rileys has an AC Delco also but it is exactly the same part as the WT203 but in an AC Delco box and has a price tag of $22. These all tested from 80-82 ohms in boiling water.
Good Luck !
Good Luck !
1979L824speed (07-11-2018)
