Drain hole in L88 hood
Old 07-30-2018, 05:13 PM
ronarndt
ronarndt's Avatar
Default Drain hole in L88 hood
I have an aftermarket L88 style hood that collects
water in the recess at the front of the hood. I drilled a 1/8 inch hole carefully at the lowest point in the recess so I did not have to soak out the water with a towel every time I wash the car. Did the factory hood have any drain hole there?
Old 07-30-2018, 05:18 PM
NONN37
NONN37's Avatar
yes. pretty much like you have. one in the middle bottom
ronarndt (07-30-2018)
Old 07-31-2018, 08:36 PM
OLE442
OLE442's Avatar
Location: Way too effing close to the city.......NRA Life Member!
When I added an aftermarket L-88 hood to my wife's Camaro years ago, I drilled a small whole in the same area. Love those L-88 hoods!
ronarndt (07-31-2018)
Old 07-31-2018, 09:11 PM
chazde3
chazde3's Avatar
My GM L88 hood:
Old 08-01-2018, 09:58 AM
terry82
terry82's Avatar
[QUOTE=chazde3;1597706091]My GM L88 hood:
Size:  1.76 MB[/QUOTEi seen at a car show ,a guy cut out the glass where the hole is and put in a screen .it did not hold water and the guy said it let out a lot of under hood heat.
Old 08-01-2018, 12:54 PM
ronarndt
ronarndt's Avatar
terry82 said "the guy said it let out a lot of under hood heat. " My hood has chrome trim pieces in the depression at the front of the hood that are supposed to be vents, but they are solid. If I get creative some day, I may see if I can make the vent pieces functional with my Dremel and actually let out the heat from the engine like they were supposed to do.
Old 08-01-2018, 03:56 PM
MelWff
MelWff's Avatar
Received 1,806 Likes on 1,597 Posts
Default Hole size
Originally Posted by chazde3
My GM L88 hood:
Any chance you could measure the size of that hole? Thanks.
Old 08-01-2018, 04:33 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
hole is about 3/16" for drain, so it can pee on your motor !
Old 08-01-2018, 04:40 PM
chazde3
chazde3's Avatar
Yeah, I will grab my calipers and measure it tonight when I am home from work.
Edit: I measured around .205-.215in. That would make it around a 13/64 drill bit.
MelWff (08-02-2018)
To Drain hole in L88 hood
Quick Reply: Drain hole in L88 hood
