License plate tag light
Hello it's crap again with a new problem with the 1975 corvette stingray.How does one go about changing the bulb for the tag light? I wanted to replace the whole light with a new one but I don't see how you get to it.Thanks for the help.
If its like my 80 you have two screw under and you take those out and the bracket drops down. if it stuck you can follow the two wires from under the car that go on top of bumper on the inside. I just then got access to the socket and cut the wires and spliced in the new unit. I actually use velcro to the rear fiberglass to angle the LED bulb as it like the way it projects.
