Car is not braking to its full potential
But its still something that can be done with little effort as a extra.
This is what I do. This should also work on a manual car.
https://www.corvetteforum.com/forums...-cylinder.html
How many miles on the pads?
They do take some time to bed in, especially on used rotors.
And
Do you have one of those IR heat guns? It is a good tool to see all your calipers are working (getting hot)
After you are sure the pads are bedded, try a few stops from highway speed. That should get the brakes up to operating temperature.
If it makes a big difference, you may need a pad that works at lower temps.
I put some Raybestos pads in my car, and they made a big improvement over the 20 year old brand X pads that were in there.
RAYBESTOS SP8XP Street Performance; Metallic (from Rock Auto)
And
No I dont have IR heat gun, but I can try the highway speed technique and see if that helps.
https://www.harborfreight.com/121-in...ter-63985.html
It will give you a good idea if the calipers are clamping down on the pads.
