Should I walk away?
Should I walk away?
This 1969 is absolutely gorgeous but has one problem area that I can't get over.
The vacuum-compartment concealing the windshield wipers was removed in '73 and the car stored outside for c. 6 years, but was then garaged afterwards. Clearly some water has got in and around the lower windshield area during the time it was outside. See pictures below.
How concerned should I be? Is this a deal-breaker? Would love to know what you guys think. Is this surface rust? Simple discoloration?
The birdcage was recently rated as in 'excellent' condition by a reputable local mechanic...which has me even more confused.
But on another note - Is this not the front of the birdcage? Sorry if that's a stupid question, this is my first rodeo. I was under the impression that what I was looking at here was the front of the birdcage.
If I go back for a second look / to commit to it, I definitely will remove the kick panel felt nervous about asking the owner to remove it on first look.
I don't think it was covered, no.
That is a fantastically useful reply. Thanks man.
What I am gathering is - people are much more concerned about rust around the windshield pillars + on top of the windshield rather than potential rust at the bottom of the windshield by the wipers?
Can anyone shed some light on why this might be?
2017 C3 of Year Finalist
C3Optimist (09-30-2018)
Received 1,468 Likes
Cruise-In II Veteran
The metal finishes where the rivets are seen.
Check the link to see more:
http://www.corvette-restoration.com/...rame-painting/
Read. https://www.corvetteforum.com/forums...-corvette.html. Also what you have showed us is gummed up, not scary.
You can see where the metal finishes in this picture:
Primoz (09-30-2018)
