Stock tire size equivalent for '74 Vette.
I just last night scooped up a pretty nice set of Corvette Rally Wheels along with the Derby caps and trim rings, now its time to find some tires for them. Would anyone know what the modern measurement/equivalent is for the stock tire size of the '74 Vette? I remember how well those old tires filled the wheel wells and would love to be able to duplicate that look with a modern tire. Any help with the sizes would be a huge help here. Thanks, TC—
How's the bump steer on tires that large on a car that wasn't "designed" for them? How's the steering and rapid handling? What's the tire height? I notice the a whole lot of C3 Vettes have a ton of air between the top of the tire and the fender lip, looks awkward as Hell to me, almost "off road" and something to avoid. Maybe the 255s will eliminate that "problem." Thanks, TC.
The tread width varies depending on manufacturer and specific tire model you're looking at. For 225/70R15 tires, you can find them from 6 inches tread width to about 7 inches tread width. Performance tires generally have wider tread, "energy saving" tires, generally have narrower tread.
"Fills the wheel wells perfectly on my 74."
That's a MASSIVE amount of air between the top of the tire and the edge of the wheel well lip, looks like well over four inches. This "off road" look is something that I'm trying to avoid. Possibly the fault isn't in the tire choice but rather the spring height or settings. I'm hoping to be able to have the front and rear spacing match up. Anyone solve this? Anyone have the same spacing between tire top and fender lip match up front and rear? Thanks, TC.
I drive very aggressive and my car handles real well in the curvey TX Hill country roads in my area. Overall tire height is 26.25" and there is slightly less than 2" gap above tire to fender.
Many guys run the 255mm tire...
Team Evil (11-07-2018)
But I'll let you in on a little secret...I LOVE IT THAT WAY.
In my opinion, most stock cars look like they are going up hill all the time.
BTW, I was referring to the width, not the height
I honestly don't know. why my back end is up, it was like that when I got it. There are no air shocks there, maybe the spring.
If you like it where it is now, you can keep it that way. It looks way too high to me, though. It won't handle as well jacked up like that, and it's very likely you've got weight jacked into the chassis. If you're going to change the ride height on these cars, it's a good idea to get a set of four scales and set the corner weights to keep the handling balanced. If you've got weight jacked into it, it will favor turning in one direction over the other, and it can even pull to one side.
255s were in fact an OEM size by 1978 and I'm not aware of any suspension "design" changes to accommodate this size on later C3s (maybe the factory trimmed the fiberglass differently on the front fenders?). However 255s can sometimes rub the front inner fenders especially if bouncing while turning sharply. Some like them on earlier C3s (aesthetically they fill up the fenders nicely). A few have reported problems with rubbing or so I've heard.
AFAIK there are NO performance tires left in any of these sizes - so it comes down to looks I suppose.
Excessive height in front can be due to new/incorrect springs. Rear excessive height can be adjusted in some cases.
One more comment, and another variable to add to the mix. Check the width of your wheels. Some C3's had 8 inch wide (15x8) wheels, and I don't know of a 225/70R15 that is recommended (or safe) to mount on a wheel that wide. Check the manufacturer's spec sheets for your tires. Most 225/70R15's are specified for 6" to 7.5" wheels, and they look and drive great on 15x7 wheels that are the most common for C3 Corvettes.
If you have the optional 15x8 wheels, the 255/60R15 tires are the best choice, and about the only choice that fits properly on those wheels.
My wheels measure nine inches from edge to edge although I maybe ought to be measuring them in a different spot.
https://www.corvetteforum.com/forums...ly-wheels.html
I'm still confused as to what the wheel size is and where to measure from. If they're the optional eight inch wheels I'll look to sell them or trade them for the narrower wheel. I found a few sets of 225/70R15 tires that are to my liking and for a good price, the larger tires seem a bit too much, seem to scrape the inner wheel well edges and are more expensive. I kinda want the car to look tastefully/mostly stock, I dislike large wheel/tire combinations in general, the current "trend" towards larger is better seems ridiculous. I have a "back-up" set of seven and a half inch Cragars if everything goes South along with the Western/Turbine wheels currently on the car, but I'd MUCH rather run these Rally Wheels if possible. Thanks, TC—
Starting some time in the 1970's, wheels were required to be marked with the size. The size designation will be something like 7Jx15H ET0. The first number is the width, the number after the "x" is the diameter. The number after the ET is the offset in millimeters.
If you want to measure it with a ruler or measuring tape, measure across the inner edges of the rim lips, like in this picture:
The wheel in my picture is 7 inches wide.
Thank you for that measuring guide as to where the ruler/tape needs to be placed, I was measuring from the outside edge of the rim side to side. I'll check tomorrow (too dark to poke around in the yard right now) and see what I actually bought.
" . . . beginning with the 69 model year 15X8 rally wheels became the standard size for C3’s." Did the stock tire size increase to the equivalent of 225/70R15 at the same time? Did the stock tires rub inside of the wheel wells on turns/while bouncing/etc. as suggested or is it a radial vs bias ply thing happening now? As the car is just a street car, I wouldn't mind running bias ply tires at all if they fit better than radials.
Thanks, TC—
Thanks, TC—
