What have you paid for new clutch replacement
Old 11-12-2018, 10:05 PM
Pbphantom
Pbphantom's Avatar
Default Cost of clutch replacements
I have a '69 roadster with an EFI 502 big block. My clutch is slipping and I'm guessing this will mean replacement (not sure if clutches are adjustable). No clue what I should be looking for or what is a reasonable estimate. Any advice would be greatly appreciated!!
Ps the tranny seems to knock every now and then...almost like something isn't tight.
Old 11-12-2018, 11:46 PM
TimAT
TimAT's Avatar
Clutches are adjustable. How much travel do you feel in the pedal before you feel resistance? There should be a minimum of 1 inch. Very easy to adjust-
You don't say where you are- check with the local Corvette club for recommendations on where to have a clutch replaced. The clutch itself is the same on just about every rear wheel drive car- but the Corvette has some "quirks" that if the shop doesn't know about could end up costing you way more than it should. I have a Centerforce DF clutch in my 69. Clutch disc, pressure plate and release bearing was about $450. Parts only.
Quick Reply: What have you paid for new clutch replacement
