What year is this engine?
Old Nov 13, 2018 | 09:19 PM
GlenJack's Avatar
GlenJack
Default What year is this engine?
Looking for some advice from the corvette engine gurus.=left
I have a 72 vert and I am sure the numbers are not matching. The block is a 350 - casting numbers 20GM 3970010. I have other numbers on the passenger side head that say 118143224 followed by what I think is V0128000. Can anyone tell me what engine I have? also, I am thinking I am going to replace the carburetor and want to know the best carburetor for this engine.=left
Thanks to all the experts out there!=left
GlenJack
Old Nov 13, 2018 | 09:22 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
On the other side of of the block where you found the 010 number is the casting date. What makes you think the carb on it now is not the best for the engine
Old Nov 13, 2018 | 09:48 PM
GlenJack's Avatar
GlenJack
It may well be, but it needs replacing or rebuilding, and I am not skilled enough to rebuild. Right now, I floor it and it lags a little. Or, if not completely warmed up, it may die (when I floor it). I have played with the fuel/air misture and got it about the best it will do, but it is still slow to respond. Wondering if I have the right cfm. This is an edelbrock 1408, which I think is 600 cfm. I'm wondering if 650 cfm may be better. And basically, I just don't know!
Old Nov 13, 2018 | 10:04 PM
derekderek's Avatar
derekderek
Eddy's come in 600 and 750. You want 650, gotta go Holley. 600 is plenty for a 350. Accelerator pump is shot. Easy fix.
Old Nov 13, 2018 | 10:43 PM
ballen06's Avatar
ballen06
The 3970010 number is a good number for a 1972 block.... It was also used in 1970 and 1971... and I believe in late 1969.
Old Nov 13, 2018 | 11:17 PM
GlenJack's Avatar
GlenJack
Derekderek. Thanks. I am thinking an easy fix for you. lol! An easy fix for me is to take it off and replace it with a new one. What would you do?
Old Nov 13, 2018 | 11:46 PM
GlenJack's Avatar
GlenJack
Casting date A 27 1. Does that mean it was cast January 27, 1971? I was told the engine was not the original and was a 74.
Old Nov 14, 2018 | 06:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by GlenJack
...V0128000...
V Flint, Michigan engine assembly plant, January 28th (0128). The last three characters are alpha and are the engine ID suffix code. Take another look at the stamp.
Old Nov 14, 2018 | 06:49 AM
derekderek's Avatar
derekderek
. What would I do? Fix it. YOU on the other hand need to watch a couple YouTube videos on Edelbrock or Carter AFB carbs before you fix yours...
Old Nov 14, 2018 | 07:06 AM
derekderek's Avatar
derekderek
Here is a quicky pull top and clean up video. Then you can decide how much more carb school you want to do. There are some very good but long videos about jetting, tuning, rebuilds, etc.
Old Nov 14, 2018 | 05:54 PM
GlenJack's Avatar
GlenJack
This is the best I can do. I can't see it any better than that.
Old Nov 14, 2018 | 05:58 PM
GlenJack's Avatar
GlenJack
And this is the other code I found ... Where I thought it meant A=January, 27 = day. 1= 1971
Old Nov 14, 2018 | 07:07 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Edelbrocks have got to be one of the easiest carbs to rebuild. You can get a kit from Summit and get it done in a day. Just install the rods last so you dont bend themYou should write down all the jets and rods so you can go to their website or the owners manual and see were you are on their Air fuel chart. It helps tune it of you dont have an Air fuel ratio guage.
Old Nov 14, 2018 | 07:40 PM
GlenJack's Avatar
GlenJack
Okay, sounds like fun. I'm thinking I may give it a try!
Old Nov 15, 2018 | 06:38 AM
derekderek's Avatar
derekderek
okay they didn't use the letter or number 0 in the engine identifier code. The first one is a c the second one is a c or a g third one cannot be read. CCC is a 307. Cgc is the 350 turbo hydro or police from a 71. You have to get some stripper or something and clean off so that all three of those letters can be read.
Old Nov 15, 2018 | 08:02 AM
Easy Mike's Avatar
Easy Mike
...The first one is a c...
I agree. First is an alpha C. VIN derivative is not Corvette and probably an Impala or Caprice which were also assembled at St. Louis.
Old Nov 15, 2018 | 12:14 PM
GlenJack's Avatar
GlenJack
Okay, interesting. Well, it is definitely a 350 so it would not be CCC. I tried to google 350 hydro and 350 police, but I don't see any good information on what those are.
I will look into getting some solvent to remove a little bit of that paint. Thanks for all the information!!
Old Nov 15, 2018 | 12:27 PM
Nowhere Man
https://www.corvetteforum.com/forums...df-format.html
down load that Lime Book That has all the engine suffix codes from 55-91.
Old Nov 15, 2018 | 03:24 PM
GlenJack's Avatar
GlenJack
Okay, did that. Thanks! I think that I have a 71 el camino engine that originally was a 2 barrel carb and a manual trans.
It has an Edelbrock manifold and a 4 barrel 600 cfm Edelbrock carb.
So, I think that is where I am. I will still look to strip a little of the paint away to see the code better, but this is a lot of fun doing a bit of investigation. Thanks for the help, everyone who has contributed thus far!!
To What year is this engine?
