LED's or Old Style bulbs?
These
Not these
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I can understand the attraction to LEDs, I would install them as brake lights. I rarely, if ever, drive the '68 at night, so dash and headlights are a nonconcern in my case.
My uniformed observation is that LEDs can be visibly brighter to LOOK AT, but not necessarily to SEE WITH.
Christmas LEDs for example are great color, but they don't seem to "throw" light. It seems very concentrated at the source.
I have a couple LED flashlights that seem blinding to look at, but don't illuminate well.
I went white gauges throughout on my '72 with green LED's in all the housings, dimmer don't work, but so what?? great change, actually see the gauges now......went LED in the front turn signals they are much brighter now, and they from a C2 the round ones.....behind the grill, but I thinking of moving them to ON the grill....lazy.... in back I think I did a LED on the license plate....but the brake light housings will not take the crappy SuperBrightLED bulbs they sent....rong flange spacing in their construction...idiots....but same thing fit the front just fine...go figger....the front side marker lights not flick maybe not even ignite, need to change to LED and rewire so always on.... I have no interior lights at all, long since removed as being not needed....
but I love my green dash lights....so easy to see at night with white face gauges....;-)
see pix below....
see pix below....
I thinking of changing over to Halogen headlights this spring. Coming home after dark on unfamilar roads from a cruise-in a month or so ago really pointed out the limitation of the high beams as compared to my daily driver. I'm normally not out in the '75 too often after dark on roads where I would use high beams, But that was an eye-opener! I need to reasearch just what is involved in the change over.
Dementer sole survivor
Received 6,257 Likes
2016 C3 of Year Finalist
When I got my car it had the stock style bulbs. Its like driving with a flash light in oncoming traffic. I upgraded to bypass the High beam switch to get 12 volts and more amps to the bulbs. It was a small improvement but still dangerous on curvy roads in traffic. I switched over from old style incandescent to halogen in H1 and H4 lenses. I upgraded to add relays and direct voltage/ amperage from the battery and it helped for a while. I upgraded my alternator to 100 amp to cover my new electric cooling fan which had the benefit of adding power for my headlight upgrade. I bought a new add on harness that plugs into the stock headlight harness at one of the headlamp plugs which is used for the relays and powering the high beam relay. It also had a bigger gauge wire for power from the battery. I took power off the starter lug. And it came with 4, 3 blade ceramic plugs for the headlights. I could run all 4 lights in low and high, which is legal in MA but I didnt want the locals to keep flashing me because they dont know the law. All i had to do was rotate the high beam plug so only 2 of the blades actually went into the plug. It works great
It was a huge upgrade and I could see the edge of the road better but then the LED bulbs and little cheap driving light upgrades got cheap and everyone has to have them. I cant see anything anymore coming home from the beach or late shows. So now I added a 8 inch LED bar just above my front license plate to aid when the driving gets difficult. I added a shield so that it knocks the light down so it doesnt blind oncoming drivers unless we are cresting a hill simultaneosly. I have some LED bulbs for the lenses that are supposed to be DOT approved. We'll see how that goes this winter
Its ridiculous that the local drivers arent educated to drive with their high beams off in oncoming traffic patterns or when they come up behind me. I'm not risking my safety for these knuckle heads anymore. In my '01 truck my high beams ( with new bulbs) arent close to the brightness of some of these newer cars. I flash my high beams and it doesnt even phase these guys.
I also upgraded to LED dash and driving lights from Superbrite LED. The ones I have dont dim and I had to mess with the turn signal bulbs to get them to fit into the socket deep enough. I'm happy with them though.
jim-81 (11-27-2018)
On my '72 it was just pull and replace, easy peasy
#34
Odd example you chose there. Yes, the look of T-bird tail lights of that vintage is great--except when backlit by low, harsh winter sun and it is impossible to tell if the brake lights and/or turn signals are on or off! The only road accident of my life was when I hit one of those in the driver rear fender as it made a left turn ahead of me onto a completely hidden left-only intersection. I admitted blame to the highway patrolman even if I think those impossible to see tail lights were the real cause.
#37
My dad had and loved his 78 thunderbird, logged just over 200k on it, so they have a sentamental tug at me.
It ran like a top, no smoke,
Had it painted once and kept everything up to par he was a navy plane tech and machinist he didnt mess around,
The seats had been covered since the day they bought it,
When he did sell it it really did look as close to showroom new that a daily driver could, the buyer was amazed,
The world goes further than c3 corvettes.
#38
FWIW, I replaced all the interior illumination bulbs with WARM LEDs. It's a bit brighter, a lot less current and heat, and preserves the period charm. Usually I prefer operating room levels of light, but not in these cars.
Outside is a different story. 68-style (paired) taillights with bright LEDs. Being seen by the other idiots more important than a warm period glow.
#39
My brother had a 77 Thunderbird he bought new. I told him several times over the years I wanted it when he was done. One day I saw him downtown and he said "I just sold my Thunderbird for $500". I was pretty angry he didn't give a chance to buy it for that ridiculously low price given its pristine interior and exterior and he was all like "Oh, I think the motor was gone, I barely made it into the city with it, you wouldn't have wanted it. I said FFS, for $500 I could have put a motor in it! I knew from experience with those years of Fords the ignition control module often went bad and the car would cough and sputter when you got into the gas at all and I'm sure to anyone not familiar it would seem like the engine was bad. I went by the Ford dealer he traded it into a few days later and they had it on the lot for $2300. I think very likely they put an ignition control module in it and it was good to go.
#40
Pros and cons,
No one right answer for all, ive been messing with leds longer than some even knew of them and love them for some things but not classic cars unless a modern resto mod look it what you desire at the cost of loosing some heart and soul of a classic,
Leds are not always brighter,
Brighter can be had with old filiment style lamps,
You have to deside if they are what you really want,
Also turn signal leds are not plug and play unless you are careful and get the ones made for it and swap to the led flashers,
As Bats says....the turn signals are the real problem....you have to change the flasher units out with compatible ones.
My recommendation is LEDS in non critical locations.....dome, footwells, clearance lights....etc...
I'm NOT impressed with the weather sealing and moisture rejection of various LED designs.
UnkaHal
