Will 68 L88 radiator support work in 69?
I am replacing my radiator with a DeWitt L88 radiator. I need a new radiator support. Many Corvette venders sell a L88 radiator support described as being for a 1968. My car is a 1969. Will a 1968 radiator support work in a 1969? Is there any difference between a 1968 and 1969 L88 radiator support? Thanks for the help.
I would say no based off of the part numbers. My 12/79 part book shows 3938090 for a 68 L88 support, and a 3966597 for a 69 L88. It also lists for the 597 70-2 350 w/hd, 4 spd, shp 70-1 w/hd rad. I'm guessing these two are the ZR1 and ZR2. Ecklers lists a 597 reproduction
Former Vendor
Thanks. I was given the radiator by a friend and was hoping to use it instead of purchasing another radiator. I will look at modifying the small block support that is in the car.
If you have a 'real' L88 radiator support, your best use of it would be to sell it on eBay for what it is. Then, just buy a good 3 or 4 core aluminum radiator which will fit in your support. You don't need a radiator with different height/width dimensions; you need an aluminum unit with more cores.
Thanks for the correction. Rows....
