Fan shroud on a 1975 Corvette Stingray
Replacing the radiator on a 1975 Corvette Stingray .Broke the shroud in two getting it out.Is there a difference between a shroud for a automatic transmission and a manual transmission? Thanks to everyone for the help
Should be the same for auto and manual trans. I cut mine the last time I removed it knowing I was going with an electric fan. I have seen where some have split it on the bottom center, that way you can collapse it together to clear the control arms for installation, then either put a patch on it or just leave the split, it wont be visible once installed.
