Bad noise coming from rear?
At least, I think it's the rear. It's been making this noise for the past 2 or 3 days, only at low speed, and only when I'm turning (specifically to the left.) I can feel and hear the noise, and it seems to be closest to the left rear wheel.
Any ideas?
https://cdn.discordapp.com/attachmen...3439/video.mov
Any ideas?
If you can "feel" the noise, start by checking the output shaft u joints. Jack the car up and rotate the wheel by hand and check for play in the shaft. Sometimes you'll need a long screw-driver to insert into the joint to check for sloppy movement.
I can tell you why. First there are no bands in a differential, there is a posi case with clutches that depending on how they are setup will chatter, sometimes a lot. GM limited slip additive is required to be put in with the gear oil to allow the clutches to slip when they get hot in a turn.
