68 427 exh manifold bolts ? What’s correct?
C2 of Year Finalist (stock) 2019
ok guys, I just bought new exh manifold bolts from paragon for my 68 427 with paw steering. Part number 1725k. Well I don’t know if they are correct? Any other exh manifold bolts I have used on other cars were a shouldered bolt as in the 2nd picture. The 2 other pictures are of the paragon box and bolt style.the paragon bolts look like sbc exh bolts too me? What is correct? Let me know your thoughts guys!
k
k
Received 6,928 Likes
2015 C2 of Year Finalist
that bottom bolt is correct. you should also got the the heavy thick washer. also on cylinder number one the front bolt is replaced by a stud for the PS bracket
So nowhere Man, are you saying the paragon part is correct? That would be the bolt sitting on the box. The shoulder bolt is not correct? You so nowhere Man, are you saying the paragon part is correct? That would be the bolt sitting on the box. The shoulder bolt is not correct?
I never seen a shoulder bolt for a exhaust manifold bolt. but I haven't seen it all
