4 Brake Lights on C3
3rd Gear
Has anyone who has successfully pulled this one off please lend me a hand.
Everything is wired correctly and I'm getting 4 brake lights and 4 hazard lights, but turn signals are not working. I'm running LED bulbs and picketed up the electronic LED flasher from Eckler's, but nothing happens when I use my signal.
Do I need another electronic LED relay for the hazards too?
Thanks, Rob
Thanks, Rob
Received 1,126 Likes
Just to amplify on sug's advice, there are two flashers, one for hazards and one for directionals. One is over in the passenger area, can't remember which that is but I think it is the hazards.
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
The flasher on the fuse block is for the hazards .The turn signal flasher is behind the passengers side map pocket .When I had led tail lights the L shaped connecter to the flasher had to be cut and connected the opposite way for the leds to work.
3rd Gear
Mine is just like this...
Both the hazard relay and the flasher relay are on the same fuse box. I’ll try to flip the polarity tomorrow on the flasher relay and see what happens.
Thanks for your help.
