Correct t-top screws
Old Feb 21, 2019 | 12:25 PM
Auggievf's Avatar
Auggievf
Default Correct t-top screws
I'm not sure why but I cant find any information on which screws are correct for my chrome stainless t-top trim that sits on top of the center bar. The screws that are in there now have a large head and I think that they are contributing to my leaking problem...
EDIT: 1974 is the year...
I think these are close but they say "rear mount"
https://willcoxcorvette.com/corvette...screws-4-piece
Old Feb 21, 2019 | 02:36 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
https://willcoxcorvette.com/corvette...iece-set-68-82
Old Feb 21, 2019 | 03:07 PM
Auggievf's Avatar
Auggievf
Hmmmmm the screws look correct but the image isn't of the piece I'm looking for screws for. Are they the same for this?
Old Feb 21, 2019 | 03:39 PM
Auggievf's Avatar
Auggievf
Also, is there anything else holding down that stainless piece down?
When I took the screws out, the stainless wouldn't budge. I assumed it was because of the weatherstripping underneath holding but didn't want to force it without asking.
I didn't see anything in my AIM but I may have missed it...
EDIT: Chrome isn't the same as stainless....
Old Feb 21, 2019 | 04:12 PM
Auggievf's Avatar
Auggievf
Found a quote from @DUB in a separate thread from a couple years ago:
Removing the 'T' shaped piece of stainless trim for your T-tops to seal on WILL require removing the front windshield trim...along with the pillar post trim. If you are willing to do that...then it can come out.
Old Feb 21, 2019 | 04:14 PM
caskiguy's Avatar
caskiguy
https://www.zip-corvette.com/68-82-c...-moldings.html
I believe the weatherstrip for what it was worth caught some of the trim and therefore held it. The rivets I believe attach to the 2 side trims and it all stays in place/Not really leak proof.
Old Feb 21, 2019 | 04:24 PM
0Willcox Corvette
Former Vendor
Yes.. the header portion of the T molding only has four screws in it. If you want the lower side screws I'll have to post back.
Willcox
Old Feb 21, 2019 | 04:55 PM
Auggievf's Avatar
Auggievf
Thanks! I'll order a set of those.
EDIT: Or maybe not... $15 to ship 4 screws???
Old Feb 21, 2019 | 05:39 PM
DUB's Avatar
DUB
The screws that go on the top of the 'T' trim are nothing special They are #8 sheet metal screws like you have on your car in numerous places.
You can have #8 screw with a #8 head or a #8 screw with a #6 head.
I cannot remember off the top of my head but I think they are #8 screws with a #8 head. And they do not have the spinning washer on them like many screws have on them.
And as you may now have found out that there are 1/8 pop rivets at the back of the trim that need to be drilled out..and screws that are along the side like Willcox mentioned...>AND screws that you can only get to when you take off the center windshield interior trim and visors.
DUB
Old Feb 21, 2019 | 06:28 PM
Auggievf's Avatar
Auggievf
Thanks @DUB ! That is exactly the info I needed.
Old Feb 21, 2019 | 06:33 PM
0Willcox Corvette
Former Vendor
Call them in.. and the only thing special about the screw is the chrome head. I'll put them up on ebay tomorrow. You can buy standard screws but the originals were chrome headed... email me at Service@willcoxcorvette.com and I can just send you a paypal. We're working on the website right now to correct the small items issue but right now there is nothing we can do... I suspect that it'll take a few weeks to fix the issue.
Willcox
Old Feb 21, 2019 | 06:34 PM
DUB's Avatar
DUB
If you do take this 'T' trim off...look at the area in the first photo in POST #6
That area is where I also pump that CRL 7708 and may also use some black 3M strip caulk to make sure this area is sealed off and water does not get under the trim.
DUB
Old Feb 21, 2019 | 06:48 PM
Auggievf's Avatar
Auggievf
Here is where I ended up.
Thanks to everyone for the help.
EDIT:. Bah.... Should have gotten half inch.... 😐
Old Feb 21, 2019 | 06:57 PM
Auggievf's Avatar
Auggievf
DUB
Thanks. That's where I was originally going but was unsure about what else could be holding the trim down. Now I know I needed to take off the other trim as well.
I do worry about bending the trim as I remove it because it the old weather stripping under there is holding real tight.
Any tricks for a smooth release or do I just lift a little at a time slowly to pull up the weatherstripping holding it down?
Old Feb 22, 2019 | 11:36 AM
0Willcox Corvette
Former Vendor
EDIT:. Bah.... Should have gotten half inch.... ��
The screws were not flat headed screws and while the 3/4" may work, the screw originally had an oval head and number 6 in size. (which is smaller than the flat headed screw you purchased).
When USPS raised the rates in Jan, we pulled all our screw listings on eBay so that we could make corrections to the shipping.
I'll have a listing up today with the correct screws if you are interested. But.. I don't think the extra 1/4 will cause you any issue... I don't think they'll hit and you got SS screws so they won't rust.... I'll still post you the link to the original screws either way.
Old Feb 22, 2019 | 11:41 AM
Auggievf's Avatar
Auggievf
Thanks! I wasn't sure about pan head vs flat head and figured the flat ones would be less likely to cause leaks. I tried to use one of the ones I bought last night but it bottomed out with about 1/8th of an inch left. Thats when I realized I needed shorter screws.
I haven't seen #8 screws with #6 heads and it seems that #6 diameter screws would be too thin to work.... I'll order a set from you once you update the listing. Thanks!
Old Feb 22, 2019 | 11:59 AM
0Willcox Corvette
Former Vendor
Until I can get the USPS shipping calculator fixed on our site for small items... (this has been driving us nuts since Jan...) ... use this link, it'll only charge you actual shipping. https://www.ebay.com/itm/123659372359
Willcox
Old Feb 22, 2019 | 05:28 PM
DUB's Avatar
DUB
I know that finding the correct type of screw....such as the #8 with a #6 head can be gotten from a place like Willcox...or like I do.I get them locally from an automotive fastener supply store that carries them so I can buy a box of 50 or a 100 when I need them.
These screw as mentioned are suppose to have a domed head and it will not cause for any leaks due to that is the way it came from the factory .
DUB
To Correct t-top screws
