Cold and Bummed Out
Cold and Bummed Out
So here we are in Mid-February, and just when I thought we were turning the corner, we got our first snow of the year last week, and a bunch more expected tonight.
I don't care to shovel the snow, but even worse, the cold, where it has been around freezing or a few degrees below.
There are so many things I want to do on my C3 and C6 roadsters, but.just too cold. Although the garage is insulated, not sealed well, and the space heaters don't seem to do a good enough job. Here's the stuff waiting on the C3:
New electronic distributor, coil, plug wires and plugs.
3 new Holleys for the Tri-Power set up.
Vacuum relay, and misc parts for wiper door and headlights
I guess I'm just kinda venting, but can't wait for better and warmer weather before I can do much.
At least all of the cars are in the garage with covers and battery tenders on all. 😉
Hope it's warmer where you are!
Rob
Rob
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
We have the opposite problem here . I bet you cant wait to get the holley 3x2s on .I went to electronic ignition and its been well worth it . Looking forward to some pics when your done .
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
I feel your pain. I put a kerosene heater in the garage. Its the type that is used in a mobile home. First time ever having a garage of my own and a place to work thats heated. Its my verion of heaven. I keep it at 55* unless I'm working out there, then I bump it into the upper 60s
surf kijiji for 1 of these. https://www.ebay.com/itm/Dayton-Torp...temCondition=4 blows at you so doesn't hafta heat whole garage.
I have tried both kerosene and propane. They will rob the oxygen out of the air and put in carbon monoxide rather quickly. You have to really vent them well. I had a huge headache in short time. My house now has 2 walls up against the house and are insulated. The other is 2 garage doors and an uninsulated wall. With no heat it will stay at about 40 degrees most of the winter. Between 20-40 degrees outside. I have a 5000 BTU cheap electric heater mounted up high. It will raise the garage to 55 in about 15 minutes.. Plenty warm to work on the Corvette all day. Dress is a long sleeve shirt and sweatshirt and I can work all day.
Normally, cold is not an issue here. We had snow in the Hollywood Hills yesterday. Snow level 1500 feet. That just doesn't happen here.
I use one of these.....
Construction heater. Plugs in to my welder plug, 220v. Lots of heat for a 22x22 ft insulated garage. From 20 degrees F it takes about an hour to get it comfortable enough to work in a sweatshirt. It also works great to get a constant temperature to do epoxy/fiberglass. And it’s safe, no worries about ignition of lacquer thinner gas etc..🙋🏼*♂️
The car has its original tri-power and TI. After having the carbs rebuilt, and set up 2X, it still runs super rich, and idles very rough(rougher than I think it should). I know there is a funky curve in the disti, so that will be my first job, see how it runs, and then replace the carbs. Spending $2500 on carbs was a last resort, but i'm sick and tired (literally) of the fumes, and having to take a shower when I get home from even a short drive, because of the gasoline stink.
Yes, I tried a propane construction heater, but as mentioned above, it filled up the garage with CO, and I too got a headache very quickly. I've used a couple of small space heaters, but when it's around freezing outside, I'm fighting a loosing battle.
This looks like it may be a solution! Do you have any specs, or a model number?
Being bad with the specifics, I had a 220V plug installed in my garage for my 4 post lift, but cannot recall if it is single phase, dual or whatever. Time to contact the electrician and check, i guess....
Cheers,
Rob
Construction heater. Plugs in to my welder plug, 220v. Lots of heat for a 22x22 ft insulated garage. From 20 degrees F it takes about an hour to get it comfortable enough to work in a sweatshirt. It also works great to get a constant temperature to do epoxy/fiberglass. And it’s safe, no worries about ignition of lacquer thinner gas etc..*♂️
My work has been grinding to a halt every winter for the past 5 years since I started my restoration project. I did get some work done in the basement on the bench top rebuilding the distributor and carburetor. Working on the A/C compressor rebuild now. As soon as the warmer weather hits I'll be outside plugging away again. Hopefully, I'll get the garage insulated this year before next winter so I can work year round.
Getting the winter blues here as well but I have a huge bathroom renovation project to keep me busy.
Got home from 10 days in HI yesterday to 10 inches of snow in the driveway. It's been the most snow here in MN in a number of years.
Times 10 on those Kerosun type heaters they can make you sick. Also their fumes can react with paint and paint stripper fumes. I used one in my first work shop and when I was stripping paint using aircraft stripper the kerosene fumes and the aircraft stripper combined to make a real nasty cloud in the shop.
Forced air in my 'new' shop.
Pic of snow plowing yesterday with my LS6/4L60E 98 wrangler.
My heater is an oil/ kerosene and I think it can be converted to gas. It is well vented to the outside. Never a headache. It uses about 1 gallon a day to maintain 55*f so my paints dont go bad, a little more while I'm out there at 65 to 70*F.
Those little Stand alone units can be a bad thing, I agree. I had one for a shed and it gave me a headache as well.
Good luck with the electric heater.
Cheers,
Rob
Rob
This is an example of the one I use. I bought it 10 years ago when I built my house and have used it every winter since. Very reliable....but it does suck the hydro. I have a 220 volt plug using #3 3 conductor wire to a double throw 30 amp breaker. I use the plug for my lift and my welder. Bit of a PITA sometimes switching plugs. I know I see them for sale on KIJIJI quite often.
https://www.homedepot.ca/en/home/sea...ction%20heater
Cheers,
Rob
Rob
Hang in there OP. We’ve had a very mild winter so far here in Round Rock,Tx. I think we’ve only hit the freezing mark once or twice overnight. Tomorrow it’s supposed to be 71* F. It’ll be a great day to cruise even though I may not be able to, others certainly can!
