Flaming River tilt column wiring adapter 68 Stingray
Picked up a hell of a deal on a new column for my brothers 1968 stingray. Basically a scratch and dent special where the powder coat was alittle scratched up down on the lower dash portion which you will never see. Picked it up for over 1/2 off. Being the OE shaft is collapsed and I am gonna have to pull the shaft completely out of the car anyways (it's stuck real hard) if you can get a deal on a upgraded unit then why not I figured. Anyways here is the issue. The current turn signal connector and such on the car is the 1/2 round connector like seen here
The connector on the Flaming River column is like this:
I would rather convert the column end of the wiring to the round type connector being the dash harness has been replaced within the last year, so I would rather reconnector the column. Any ideas where I can source the appropriate connector?
Dementer sole survivor
Received 6,255 Likes
2016 C3 of Year Finalist
I believe IDIDIT uses the same style adapter. You could check there. Maybe Lectric LImited
I have a turn signal connecter left over from when I replaced mine, if I can find its yours if you pay shipping
