The head lights won't come up
When I turn the headlights on they only rise a couple inches . I checked the hoses and replaced power brake booster and Headlight Door Vacuum Actuator (I bought the pair and one was bad). Any ideas?
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Well this is a loaded question. It could be a number of things. You need to start from the beginning and go thru it to figure out the issue. If you search the forum you will find endless posts about how to diagnose the vacuum system step by step.
Lots of diagrams and illustrations are available. A warning, there is an error in some of the diagrams that have been floating around. You can also go to Willcox Tech page, Ernie has some great info:
http://repairs.willcoxcorvette.com/c...uum-schematic/
Start from there and ask questions if you get stuck!!!!
Good luck! Ike
Good luck! Ike
Received 1,244 Likes
Here's a good how-to:
Just go step by step and test each part.
http://www.corvette-101.com/vacuum.htm
Thanks Peterbuilt
What should the vacuum pump show number wise. I blocked off the brake booster and that wasn't the problem. the filter and check valve are new. At lease the whether is getting better. Thanks for the link i print it and also the one from Ike
Bill
Bill
Peterbuilt (03-15-2019)
Ike
a year and half ago I replaced the headlamp actuators. Bought the pair from CC on sale and one was bad. They wouldn't replace just one. I had it to long.
Bill
Bill
As general ike says test the new parts as many are brand new but no good so test first.
Many times the seal (grommet) in the actuators needs to be replaced, the next problem is the relays being stuck.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1968-1982 Corvette Headlamp Vacuum Diagnostic Help.
