Chassis Builds - Lets See Them Folks
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Moving towards building myself a new rolling chassis complete for my 1974 Convertible and thought I might ask you folks what you have done with your builds.
Did you do anything special with your frame while it was off the car?
Did you paint or powder coat, or POR-15 the frame?
Did you change out the body mounts?
Did you beef up the welding seams?
Add or replace any gussets?
Show your work and lets have a chassis fun day.
And thank you in advance for sharing.
David Howard
AllVettes4Me
David Howard
AllVettes4Me
OldCarBum (04-15-2019)
leigh1322 (04-13-2019)
Received 6,943 Likes
2015 C2 of Year Finalist
this is a 65 build. just sand blasted and powder coated
Living the Vette life....
Hi David! Working on mine now and I did do the full frame weld plus added gussets at the lower control arm mounting points. Then had the frame sand blasted and powder coated. Oh and thanks for dropping the box for the core support off at John's.
In process but doing it old-school. Hand prep followed by rust encapsulator, then chassis black. If I had the $ and a convenient provider I would have loved to have it dipped, blasted, and powder coated but it is not to be. I also welded all seams and added gussets.
Had this guy I know named David restore mine. He did a pretty good job on it!
Sent him this rusty ol thing
Attachment 48348497
Got back this nicely restored chassis
Attachment 48348498
Attachment 48348497
Attachment 48348498
MattoonVette (04-15-2019)
Cleaned the frame up myself using hand wire brushes and rotary wheels, welded up most of the seams, fixed some cracked areas, painted with a POR-like rust-preventative paint called Chassis Black. Here is a pic right before mating the two back together:
