1972 350/350?
1972 350/350?
Hi all. Just purchased a 1972 with an original 350 in it. My centre console plate states 350 hp but all my googling only shows the 72 year coming out with 200 hp and 270 hp options. What motor do I have?
Please excuse ignorance, am trying to learn as much as I can though. Cheers
Received 1,469 Likes
Cruise-In II Veteran
This is my favorite site for looking up engine codes, VIN and trim tag codes, etc:
http://corvettec3.ca/
Mike H. (05-07-2019)
CI 6-7 & 9 Veteran
Welcome. If this motor is stock and it is not a LT1, it is the 200 HP motor. There is however, a misconception out there that the 72 has less HP than the 71, which listed its HP as 270 HP. In reality it is the same engine but the government changed the way HP was published. Of course the engine could have been changed, that is easy enough to find out by checking the numbers on the engine.
69FASTFUN (05-08-2019)
Has been fun learning about what all the VIN and engine codes mean. Learning heaps. Thanks again
Just another Corvette guy
'71 & '72 engines had the same HP, only the yardstick they used to measure with changed. Net hp vs. Gross hp.
Greg
The following 2 users liked this post by Greg:
crawfish333 (05-07-2019),
Doughann (05-07-2019)
Mystery solved.
Engine rebuilt to 1970 specs (about 15 years ago) and now 350 hp (actually 375hp). Hence the console plate change. Still same "original" engine.
Thanks for info on 71 and 72 being same hp, good to know. Cheers
All good info.
OP
'70 had Very different heads & pistons than low-compression '71 & later ...
... was yours rebuilt to the rather high-compression spec of 1970? Any spark rattle w/ pump gas?
A rebuild w/ small chamber heads and/or hi-comp pistons will increase compression.
A peek under a valve cover will show a head casting number ... that'll identify which sort of heads it has.
OP
Drifting into off topic, but it's an interesting detail, I think.
Martin
Sticker speed!
$20 for 75 HP...such a deal!
Run the engine pad numbers....thats 'closer' to the truth. Then look at the casting 'humps' on the end of the heads....that will tell you if it's a big valve head. Then measure the harmonic damper diameter....8" = hi-po 6"- lo-po
unkahal
Lol, might invest in a big block console sticker now. Will post more details on mods tonight that were done to 70 specs apparently. Either way, was wrapped with condition of car on delivery last weekend and motor rebuild was just a bonus. Never drive her hard so isn't really an issue if she's 270hp or 375hp (as claimed). Just happy to have a chrome bumper back in the shed 😁😁😁😁
Rebuild included, bored .030 over, 11 to 1 forged pistons, SR Torquer heads 67cc chambers, 350hp cam, hydraulic lifters, roller rockers, 750 Holley with sec, ss exhaust. Not hugely into the tech side of motors so not sure how good, bad or indifferent this is but happy it's got a rebuild and runs great.
good specs... if it has the big valves.
if its original heads in 72 with base motor, then it is not the big valves. so it may not breath as well with those specs
you just have to run the casting numbers and dates under your valve covers. could be replacement heads of course
Doughann (05-09-2019)
Old Pro Solo Guy
That should run really nice. I think I like the 350HP motor almost as much as the LT-1 I owned for decades.Regardless of who did it, check the distributor tune vs Lars's papers.
Especially if you find it pings or needs octane booster.
Thanks for the positive feedback everyone. Is a nice bonus that the engine was upgraded. Didn't really realise until after I got the car so made the purchase even better. I assume the 350+ hp motor would be quite different than the original 1972 270hp to drive
