Did you try a squirt down carb throat? Fuel pump pulls harder at faster than crank rpm. Or maybe try an outboard motor hand pump bulb. Also, remove fuel line from pump. Stick a piece of hose on the end and see if you can blow through it into the tank. And see if someone can hear bubbles in tank at filler neck.
