Fuel Additive question...
Old 06-15-2019, 05:22 PM
KC-Vette
KC-Vette's Avatar
Default Fuel Additive question...
I recently acquired a '72 Coupe with full documentation which includes the standard 350 ci engine. I am well aware of the need to supplement my fuel with a lead additive for valve seat and guide help/protection for this car. With our gasoline of today, what would you suggest? Also, what is everyone's thoughts on the Octane levels?
Thank you in advance!
Old 06-15-2019, 06:26 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
72's were produced after the EPA got its paws into the auto industry. There is no need for a lead additive to 'save' your valve seats. GM was hardening seats well before any requirement of removing lead from gasoline.
Old 06-16-2019, 10:21 AM
Eliredandblack
Eliredandblack's Avatar
For what it’s worth, I have been adding oil additives when changing the oil on my 73 small block. I believe most people agree that it helps with our older engines.
Old 06-16-2019, 10:44 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
http://www.wildbillscorvette.com/OctaneSupreme01.htm
Old 06-16-2019, 11:47 AM
Duane4238
Duane4238's Avatar
Also, read your owner's manual and make sure you're using the correct octane fuel. Even the base engine models don't use regular 87 octane. I think at least 91 is suggested. I always fill up with 93, as my station only has the 2 choices.
Duane
Old 06-16-2019, 12:12 PM
MelWff
MelWff's Avatar
Received 1,806 Likes on 1,597 Posts
you have a low compression engine with hardened valve seats, Nothing is needed.
Old 06-16-2019, 02:23 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
Do your wallet and car a favor by only putting gas in your gas tank. Buy the lowest octane gas that does not make your engine ping under load.
Old 06-16-2019, 02:26 PM
7T1vette
7T1vette's Avatar
I stand outside my front door every eveining and produce the loudest Tarzan yell I can muster, in order to keep the elephants away. It's working....
Old 06-16-2019, 03:52 PM
HeadsU.P.
HeadsU.P.'s Avatar
Received 2,108 Likes on 1,619 Posts
We all pretty much use an oil additive. Its called zinc. But that's a different story than a gas, lead substitute additive.
I can remember when lead was removed from pump gas. About a year afterwards the rocket scientists said the lack of lead would damage the valveseats. That was how many decades ago? I am still waiting for any documentation that that damaging event has actually taken place.
Its B.S.
ntfday (06-16-2019)
Old 06-16-2019, 03:58 PM
Nowhere Man
Its B.S.
buy the right oil and you wont have to worry about a thing.
Old 06-16-2019, 04:52 PM
HeadsU.P.
HeadsU.P.'s Avatar
I do! Lucas Hot Rod Classic. But it still has an additive right?
Old 06-16-2019, 05:11 PM
Nowhere Man
What additive? Oil with a API service rating for diesels engines has everything you need.
Old 06-16-2019, 07:14 PM
HeadsU.P.
HeadsU.P.'s Avatar
The additive is zinc. Like millions of others use with Flat Tappet cams.
Old 06-16-2019, 07:42 PM
Nowhere Man
It’s formulated in for the right API service rated oil.
Old 06-16-2019, 08:12 PM
7T1vette
7T1vette's Avatar
I thought this thread was about lead and valve seats....not zinc and cam lobes....
Old 06-17-2019, 04:52 PM
KC-Vette
KC-Vette's Avatar
Thank you to all who responded. I will continue to fill up with 91 octane, and only use top tier oils when its time to change oil.
Old 06-17-2019, 05:41 PM
Nowhere Man
Brand means NOTHING pay attention to the API service rating
Old 06-18-2019, 12:20 PM
Bergerboy
Bergerboy's Avatar
My understanding, is that the lack of lead is less of an issue than the presence of Ethanol.
For my '69 SB350, I use mostly 90 octane pure gas (no ethanol).
My routine for a tank on E, is to first put about 5 gallons of premium race fuel (110 octane, leaded) at $7.69/gallon (zoiks!) at the BP station in my town.
Then top it off for the remaining ~10 gallons with the 90 octane pure gas. I use Sunoco at about $4.50/gallon, but you can find an App that locates stations that sell pure gas via your phone's GPS.
Old 06-19-2019, 12:03 AM
7T1vette
7T1vette's Avatar
Some folks buy caviar, but I doubt that it has any better nutrition than other MUCH less expensive foods. So, if you feel that your car deserves better and/or runs better by putting fuel that is multiple times more expensive that what the manufacturer states that it needs, so be it.
ntfday (06-19-2019)
To Fuel Additive question...
Quick Reply: Fuel Additive question...
