oil change frequency
Old Jul 25, 2019 | 04:45 PM
Hdavis's Avatar
Hdavis
Default oil change frequency
I bought a 1982 corvette 8 months ago and had the oil changed when i purchased it
ive put less then 800 miles on it since. My question the sticker says change oil at 72k
should i change it sooner does the oil degrade even if your mileage is low
Old Jul 25, 2019 | 05:14 PM
nutsy's Avatar
nutsy
is it your daily driver? if so change it when it says. I only put around 5 or 6 hundred miles a year on mine and I change it once a year.
Old Jul 25, 2019 | 05:27 PM
Hdavis's Avatar
Hdavis
No it’s not a daily driver
im just wondering because they always say change it every 3k Miles or 3 months
just wondering if it degrades over time
Old Jul 25, 2019 | 09:02 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Once a year is fine.
Old Jul 25, 2019 | 11:13 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Every 3/3 is way too soon. Once a year or 5,000 miles whichever comes first for a weekend driver.
Members say it is moisture/sulfur/acids that build up in the engine and degrades the oil when a car is driven only a few hundred miles a year.
(I think you meant 7.2K)
Old Jul 26, 2019 | 01:09 AM
Hopper12's Avatar
Hopper12
^^^^ Doorgunner and team are right on. Use one of the synthetics with high zinc content and change once/year. You'll be good. The old 3 month/3000 miles is loooooong gone. Enjoy your C3!!
Old Jul 26, 2019 | 05:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Who changed your oil and what did they put in it? You need oil with high levels of zinc and phosphate or you'll be investing in a new cam soon. If they used an oil designed for flat tappets then you can change it when you want 3k or 5k or the 7k they said. Just keep an eye on the dipstick, make sure it stays full and when you start to see it getting dark change it if its before the higher mileage marks these oils can go to. I change mine once a year but I only put on about 5k a summer and I keep topping it off.
Old Jul 26, 2019 | 09:14 AM
stingr69's Avatar
stingr69
Oil change businesses are in the business of changing oil SO many years ago they "created" the 3000 mile oil change interval to keep you coming back as frequently as possible. They have been doing it so long that many people now BELIEVE THEM that 3000 miles is the correct interval. Your owners manual has oil change service interval advice and you should take a close look at that.
Old Jul 26, 2019 | 10:21 AM
7T1vette's Avatar
7T1vette
Regular 'organic' oil will oxydize, just sitting in the oil pan. If your car only gets a couple of thousand miles use per year (or less), you should use full-synthetic oil, which doesn't degrade with time like organic oil. I use full-synthetic and change it once a year. If I reach 3000 miles during the year, I only change the oil filter and add another quart of full-synthetic....THEN change it all when the year is up.
Old Jul 26, 2019 | 05:45 PM
kodpkd's Avatar
kodpkd
What oil is high zinc oil?
Old Jul 27, 2019 | 01:34 AM
Hopper12's Avatar
Hopper12
^^^^ Here is a good thread with lots of info. IMO, higher zinc levels are good for all older engines. I run Mobil 1 15-50 in my solid lifter 427. I also ran it in my '72 SB. Lots of good choices. Hope this helps.
https://www.corvetteforum.com/forums...t-oils-10.html
https://www.hemmings.com/blog/2012/1...older-engines/
Old Jul 27, 2019 | 09:52 PM
7T1vette's Avatar
7T1vette
Zinc component is important with flat-tappet cam systems...especially if you wind them up tight and often! For low performance stock engines (hydraulic lifters), you don't need to add zinc, if you use decent oil.
Old Jul 28, 2019 | 10:09 AM
bkvette3's Avatar
bkvette3
Old school way of thinking but my father used to say - "oil is cheap - an engine isn't". All my rides/toys have frequent oil changes. Never had any engine issues.
To oil change frequency
