spark plug wires
Old Jan 16, 2020 | 07:00 AM
fake's Avatar
fake
Default spark plug wires
Has any one know the Xact spark plug wire set manufacture GP Sorensen of quality on a HEI car 1977. Have had this set for 20 plus years and are 8mm High energy suppressed ignition cable. I assume they are correct for a 1975-1979 Corvette.
Old Jan 16, 2020 | 10:45 AM
jackson's Avatar
jackson
I may be preaching to the choir ... it seems GPS no longer markets sp wires
GPS is still in auto parts marketing business and is a unit or Standard Motor Products ... but no GPS wires.
There's always the possibility of NOS sp wire sets on fleabay etc but you'd need the set/part # and that's not shown in GPS eCatalog
Maybe a longstanding parts store near you would archive (stacked in a dusty box out back) obsolete countermans' catalogs.
https://www.gpsbrand.com/en
good luck
Old Jan 16, 2020 | 11:31 AM
jackson's Avatar
jackson
GPS' parent SMP has another unit BWD ... BWD markets sp wire sets ... looks like BWD pn CH837 should fit yours ... dunno who carries them
link is wonky but doable
https://www.bwdbrand.com/en/ecatalog?year=1977CH837
Spark Plug Wire Set
POP: D Per Car: 1
CHECK YOUR FIT
Add to Saved List
Installation InstructionsPart Specifications
  • Car/Truck:Truck
  • Wire Set Import / Domestic Domestic
  • Wire Diameter (mm):8mm
  • Core Construction:Mag Core
  • Cylinders:8
  • Grease Pack:Teflon Silicone Grease Pack
  • Insulation:EPDM
  • Jacket:Silicone
  • Spark Plug Wire Lead 1:22.5"
  • Spark Plug Wire Lead 2:26.5"
  • Spark Plug Wire Lead 3:28.5"
  • Spark Plug Wire Lead 4:28.5"
  • Spark Plug Wire Lead 5:44.5"
  • Spark Plug Wire Lead 6:48.5"
  • Spark Plug Wire Lead 7:56.5"
  • Spark Plug Wire Lead 8:56.5"
  • Total Number of Leads:8
  • Warranty:Life of the engine
Old Jan 16, 2020 | 01:32 PM
fake's Avatar
fake
Thanks Jackson they are for HEI. I guess angled ends are only for HEI systems
Old Jan 16, 2020 | 03:58 PM
revitup's Avatar
revitup
Spark Plug Wire Set
POP: D Per Car: 1
CHECK YOUR FIT
Add to Saved List
  • Car/Truck:Truck
  • Cylinders:8
  • Insulation:EPDM
  • Jacket:Silicone
Those wire no./lengths are all mis-identified.
Old Jan 16, 2020 | 04:25 PM
jackson's Avatar
jackson
Yes, OE wires for 77 HEI are 90 angle at both cap & plug
either of these sets should do well ... either under $30/set
DENSO
https://www.rockauto.com/en/moreinfo...WrslFVqa6ma2lm
ACDELCO
Old Jan 16, 2020 | 10:52 PM
revitup's Avatar
revitup
ACDELCO
I just installed this set. They were all a couple of inches longer than OEM which wasn't an issue.
To spark plug wires
