Distributor Dramas
the motor now starts and runs well . What have we unplugged and what problem will I cause to happen
https://www.corvetteforum.com/forums...nyone-196.html
I can't cite a source, but I believe that some Corvette seat belts have pendulums in them, such that they only lock up under heavy braking (or an impact). I assume this is an inspection item for you?
Every GM car in 1981 had this setup no matter what you bought......and when I was a kid my Dad used to make a killing deleting this sad system when they would go bad.....most did around the 50,000 mile point.......mostly G-body V-6 Monte Carlos, Regals, Cutlass, Grand Prix....
The good news is that it is relatively easy to get rid of this.......
https://www.rockauto.com/en/moreinfo...041118&jsn=542
The carb is a little tougher........since you are in Australia.......find a good core on E-Bay and have it refurbished......Lars here does excellent work but may be too far for you.
Another alternative is the /41654175 Holley Q-Jet replacement:
https://www.summitracing.com/parts/HLY-0-6210/
DO NOT buy a standard square bore carb and adapt it to the Q-Jet manifold.......it is NOT the way to go......a LOT of people will tell you this is ok but it is a terrible setup.
DO NOT buy a refurbished Q-Jet from an aftermarket rebuilder........there are many horror stories......
Jebby
Maybe your mechanic or who ever is doing the trouble shooting could ohm out the four wires to eliminate the variable of having a damaged/broken wire, before replacing the computer?
where you based?
you might want to fill in your profile so people know where your from for when they make repair suggestions,
it's not as simple for us to run to the corner store for parts for these cars.
I have a good friend who 'back in the day' never took the time to learn how to maintain the CCC system and pretty much damned every one he ever saw as a 'junk' system. At the time we both had GMs and he took his same year GM and deleted the CCC and computer stuff. Took him a while and cost a fair bit to convert. He 'converted' a lot of cars he bought. In every case he ended up with a lousy-idling car that generally ran like crap (IMO) and would have to 'tweak n tune' the carb and ignition about every 5000 miles, got crappy fuel economy too. Ironically, years ago he suddenly 'got into' EFI vehicles ...probably out of 'need' and he says looking back he spent a lot of time only to go backwards.
I go to the classic Jeep forums quite a bit ..and Ive said this before: It's really common guys who just bought a first-gen EFI jeep show up and can't get it to run right and out of the shute blame the computer ..that it's junk. They just threw $100 of new sensors at it and still can't get it to run right. About 90% of the time it's bad vacuum hoses, intake leaks (carb leaks in your case), or poor grounds/wire connections. We walk them through the problems, they find a vacuum leak or carbon'd up throttle body and then it runs great. It's almost NEVER the computer. The key to troublshooting just about ANY EFI system is to start with the basics first. Make sure the things that fail 90% of the time are in good working order. Even with modern vehicles.
While not up to the sophistication of a modern EFI system, it's essentially an electronic fuel management system, and great for it's day. Your engine will operate much better if you educate yourself and keep it running like it was I would advocate. A lot of your hoses are probably brittle as heck, and some sensors could probably use replacing. Those items are generally really cheap to buy now. The more stuff you start pulling off, you'll go backwards and be worse off I believe (trans lock-up etc). Plus a cleaner engine is lot better for the environment if that matters. The information is out there (and on Forums). You should buy this book:
https://www.ebay.com/itm/GM-Product-...oAAOSw3pVZ2lTB
P.S. Love Australia ...was there not that long ago!!
https://www.ebay.com/itm/Snap-On-MT2...sAAOSw7PNeQEO5
Or if you REALLY want to go vintage:
https://www.ebay.com/itm/OTC-system-...0AAOSw54NeHejj
(but I would definitely go with the snap-on!! over the OTC)
