ECM Clarification
Old Feb 14, 2020 | 01:54 PM
Redsoxnation's Avatar
Redsoxnation
Default ECM Clarification
I have read the threads regarding the 84 ECM installation into an 82. However, I am slightly confused, maybe more than slightly. I understand that an 84 ECM for an automatic is compatible with an 82. My question is do I use an 82 PROM or an 84 Prom?
As always, clarification is greatly appreciated.
Old Feb 14, 2020 | 03:28 PM
Fast81's Avatar
Fast81
Whats your purpose with this mod ?
Old Feb 14, 2020 | 03:33 PM
Redsoxnation
It is my understanding that 84 ECM provides greater diagnostics and the HyperTech PROM provides performance and drivability improvements.
Old Feb 14, 2020 | 04:03 PM
Fast81's Avatar
Fast81
Is your present ECM dead ? Hypertech already makes PROMs for it too..................................... ...
Old Feb 14, 2020 | 04:18 PM
Redsoxnation
Fast81 - I may not be making myself clear.
It is my understanding from reading threads on this site that upgrading from an 82 ECM to an 84 ECM has inherit advantages, IE drivability improvements, throttle response time.
If I upgrade to an 84 ECM do I need the PROM for an 84 or 82?
Does upgrading to a Hypertec PROM for an 82 provide previously stated upgrade capabilities?
Old Feb 14, 2020 | 05:16 PM
7T1vette's Avatar
7T1vette
I don't know for sure, but I would think that an '84 ECM should get the "84 PROM. It is possible that an updated PROM might not be compatible with the '82 ECM.
The drive trains were essentially the same; but there were 'improvements' in 1984. And some of them might not be translatable.
Old Feb 14, 2020 | 05:22 PM
Fast81's Avatar
Fast81
I'm not THE resident XFire expert (his name is Bucanner) but i dont think you'd know the difference between an 82 ECM with a hypertech chip and an 84 with its hypertech too.
The chip for either advances the timing a bit and delays the TC lockup to prevent the low RPM lugging GM created while chasing every % of MPG - thereby making the car feel more responsive and powerful.
Some swear BY them, some swear AT them
I have a stock 82 ECM with a hypertech "off road" version running a ZZ4 crate motor under a modified XFire top-end (renegade intake, 90lb injectors)
Old Feb 16, 2020 | 02:36 PM
Redsoxnation
7T1vette
I agree that it makes logical sense that an 82 prom would go into an 82 ECM and the same for an 84. I have read that the 84 ECM is compatible with an 82. What I am researching s if I purchase an 84 ECM could I use my current GM standard 82 PROM. The current ECM is fine it is just that I have read that the 84 offers improvements to the 82.
Old Feb 16, 2020 | 03:47 PM
SwampeastMike's Avatar
SwampeastMike
Did some searching and from everything I find you use the '84 EPROM with the '84 ECM. Note that the EPROM MUST be for an automatic!
I wouldn't expect mudh/any performance change. From what I find the main reason for the swap is that replacement ECMs for a '82 are far more expensive than for an '84. The '84 CPU does have a faster clock speed and [may] offer more diagnostic tools--I'm not sure.
To ECM Clarification
