I bought a C3 a few months back and am going through fixing the various leaks and issues before I get it painted.
I saw on Ecklers a reference to 77E, M, and L parts... and best I could find is that means 'Early', 'Mid Year', and 'Late' models. Mine seems to be a bit of a 'Franken Car'. The hood has the L82 emblem, but the VIN shows it isn't an L82. I was looking at a video on removing the door panels and the '77 in the video had a different door panel than mine. The proportioner valve isn't in the spot the Haynes Manual or online vids show it should be in, there is no security lock on the driver's fender. The previous owner worked on the motor and removed all the emissions and I think he may have done 'other mods'... not necessarily good ones. Is there a reference somewhere on the differences between an E,M,and L? Parts should all be the same I would think, I just want to know a bit about the car I have.
Hello -
Early 77's had the alarm switch on the drivers front fenders and might have a Stingray emblem instead of crossed flags, horn button could be silver if the original owner didn't bring it in for the recall. Also could have an orange engine block instead of blue. Mine is what I'd say would be a mid, year and it was built in March, it has the alarm switch in the door lock and has crossed flags on the fenders. Late ones could have a different air cleaner is what I've heard. You can go to the link below and figure out approx. when it was built. I hope this helps.
Happy Motoring, Frank
Build date on trim tag inside front door inch or 2 from dash pad. A 1 would be August or Sept 1st.Not sure if August or Sept is 1st month of production.
It can be confusing for sure, The AIM will show parts and revision dates that will help.
There were 3 different driver side front fender displays.
Early: Alarm Key only No Cross Flag Emblem
Mid: Alarm Key & Cross Flag Emblem
Late: Cross Flag Emblem Only. Alarm Switch Was Incorporated Into Drivers Door Key
A Stingray Emblem Was Never Installed On A 1977 Front Fender
The things I would look closely at are the Electrical harnesses and T-top weather stripping.
Electrical: 1st design VIN between 02287-27372 & 2nd design between 27373-49213
T-Top weather stripping:
70-77EUses a separate metal retainer to attach weatherstrip to side of T-Top panel and uses 19 fasteners.
77L-82 Uses a built-in metal retainer to attach weatherstrip to side of panel and uses 18 fasteners.
Other weather stripping 70-77 is pretty much the same.
I also purchased a Haynes manual when I purchased my 77 way before the inter-webs. I quickly found, not going to cut it. The AIM (assembly manual) in the .pdf version (personal preference) and the 1977 Chevrolet Passenger Car Service Manual (Green Cover) are a must have.
Other weather stripping 70-77 is pretty much the same. I also purchased a Haynes manual when I purchased my 77 way before the inter-webs. I quickly found, not going to cut it. The AIM (assembly manual) in the .pdf version (personal preference) and the 1977 Chevrolet Passenger Car Service Manual (Green Cover) are a must have.
Do yourself a BIG favor and get the AIM and a shop manual sooner than later. I bought a Haynes manual right after a got my car and now it takes up space in one of my tool boxes. The manuals I use live on a shelf in the garage for easy access.
According to the VIN decoder it says birthday is March 24, 1977. So someone has done work on this car it seems. Wouldn't that be considered an E, and should have the alarm key on the driver's fender but not emblem? Mine has the crossed flags but no alarm key. I haven't checked the T-Tops yet. Engine block in mine is blue, but I'm not going to go by that since the previous owner did mods and it may not even be the original motor, although he said it is.
Model year is august to may or june. That is pretty late. Half the cars built in calander year 77 are 78's. I think moto posted the actual vin number borderline between the 3 1977 versions.
Ironically, my '77 also has the L82 emblems on the hood, though the VIN indicates it was not L82 coming out of the factory. Someone will have to correct me if I'm wrong, but I believe some of the modifications can be done to the engine to make it "L82". FWIW I have a later model...no alarm key, cross emblems.
Interesting... factory mistake or over the years someone added it to make their car look like it's an L82?
L82 has 4 bolt mains. Better crank and rods as well as forged pistons. L48 is 2 bolt mains. Lower compression, cast reverse dome pistons. Yes it is possible to convert a 2 bolt main block to 4 bolt. It defiantly doesn't look factory. But some claim it's even better.
far more likely that someone added the emblems at a later date.
my Dec. 1 build early 77 came with the ugly aqua/blue engine. I painted it black long ago.
I live in Australia, amazing how many ******* put chevy emblems on there Holdens. Not sure who there trying to impress.
...According to the VIN decoder it says birthday is March 24, 1977...
What's the time built code on the trim tag? The 1977 model year began in August, 1976. A 77 assembled in March, 1977 would be coded H. Last car built in February was #24662; last car built in March was #29041. Post your VIN.
there are many c3s out there wearing false L82 emblems... back in the day people added them for show the engine would need forged internals and a 4 bolt block as well as different cam.. none of which is going to make a big difference to a weekend cruiser. the L48 actually was reported to be peppier and more responsive for street driving by car and driver in the day due to the torque curve coming in lower.
Just seen you already stated what I just responded with..Here in the states we have a lot of korean made deawoos with chevy emblems on them from the factory these days so could be worse.. in the end they are all GM products at least..its all marketing these days.
Mine is 439086, so definitely late year make. And I do believe my emblems were added to look cool. I havent bothered to take them off yet, but if I go through with the paint this winter, they'll come off then.
Same with mine... 428052. I'm probably getting a new hood for mine anyway, the previous owner for some reason took the hinges off and put hood pins in. I guess it makes working on things easier, but NOT if it's just you! The weight of the hood isn't an issue, it's the bulkiness of it that makes it very difficult for one person to take off and put on. There are some cracks in the hood too, so I may get different style, either way the L-82 emblems are coming off when it gets painted.
someone did that to the 76 my uncle bought.. He hates it.
