Wiper switch wiring
Old Jun 29, 2021 | 08:45 AM
kanvasman's Avatar
kanvasman
Default Wiper switch wiring
I am starting my underdash wiring on my 78 restomod. Custom wiring in the entire car thanks To Ron Francis and I am putting in a new oem wiper switch but don’t want to reuse the old wires. Does anyone make a replacement pigtail for the connector on the switch (non pulse).? Or a source to replace the circuit board connectors themselves and install into the oem plastic plug. And while I am in there is there a relay in the circuit. Can.t see one in my circuit diagram but want to make sure. Or determine if I should have one since I have done that on most of themother aux circuits like this. Not sure. Thanks.
Old Jun 29, 2021 | 09:24 AM
Duke94's Avatar
Duke94
If you are rewiring, this GM book is very useful.
https://www.ebay.com/itm/16482805708...AAAOSw3otgf8su
Old Jun 29, 2021 | 10:14 AM
Richard454's Avatar
Richard454
Hey Jim-
posted this a while back. might be of some help-
Here you go- a $20 work around-
https://www.amequipment.com/shop/roc...d-wiper-motors
https://www.corvetteforum.com/forums...rk-around.html
Quote:
Originally Posted by bmotojoe View Post
Richard,
Could you update your switch wiring to existing 77 wiper switch colors? Connector located about halfway down steering column.
Here you go-
Hope this helps!!!
Richard454 is online now Report Post
Old Jun 29, 2021 | 10:55 AM
bmotojoe's Avatar
bmotojoe
The 77 wiper switch connector housing is different on the 77 but the circuit is the same non-pulse.
There is a number under the switch that looks like it starts with 2004---- and then unclear.
This is the harness side connector housing for the 78 switch.
If someone has a clearer copy of that number please post it...
Here is the switch on the line diagram, you can see what looks like to me 2004-----
Old Jun 29, 2021 | 07:51 PM
kanvasman's Avatar
kanvasman
Duke,thanks for the resource for the electrical wires. Richard that is a good work around but i already am replacing the switch in the dash. That was one item I didn’t want to change. And BMO I read the thread but the only issue I have ( or want to be proactive about) is the 40 yrs or so of corrosion on the contacts is the plug itself. That’s why I was asking for a replacement pigtail that would match right up to the oem switch. I suppose once I figure how to get the contacts out of the plug I can just clean them up. I will then make the proper splices and put new wires to the motor. Thanks for the input all.
Old Jun 30, 2021 | 01:03 PM
7T1vette's Avatar
7T1vette
Is there something wrong with the stock wiring? Those dash wires are well protected and usually in good shape...unless there was a fire or car was in a salt-water flood.
Old Jun 30, 2021 | 02:33 PM
kanvasman's Avatar
kanvasman
Actually it's not in that bad a shape, Just some corrosion on the terminals from the old switch that I am replacing. All the other wiring in the car is new and I find myself obsessing over little thinkgs that in reality, I most likely won't be driving the car in the rain, so who needs the wipers to work!!! But in tearing out all the old wiring, I came across so many burned or melted wires and connected that I just started over from scratch, with a new custom harness. First order of businmess was putting the fuse box in the gloove compartment so these old bones don't have to lay on the floor upside down. I have a call out to http://www.delmarwire.com. They have just about any type of pigtail you can think of, so I will see what they say. Thx.
Old Jun 30, 2021 | 02:43 PM
kanvasman's Avatar
kanvasman
I just found what I need. They are called Pack Con connectors. and what it looks like. The only downside is I don't have to buy a new tool to ass3emble them. I already have one...
Old Jun 30, 2021 | 02:55 PM
bmotojoe's Avatar
bmotojoe
You have to be careful, there are PAC-CON 1, PAC-CON 2 etc.
If your going by your photo the crimp connector looks longer then a PAC-CON 1 terminal.
More like a Blade style fuse terminal.
Scroll down the page a little...
Here are a few different PAC-CON 1 terminals
https://www.mouser.com/Aptiv/Connect...z0yy6bZ1z0x9rq
Your on the right track anyways...
Old Jun 30, 2021 | 03:00 PM
bmotojoe's Avatar
bmotojoe
I haven't seen your harness FM connector so it maybe a PAC-CON 3 terminal.
Here are some PAC-CON 3 terminals
https://www.mouser.com/Connectors/Au...z0yy6bZ1yzmtmm
Old Jun 30, 2021 | 03:05 PM
kanvasman's Avatar
kanvasman
thank you Joe. I will double check to get the correct one, but I have never had a reason to look at these things before. Learn something new every day. Or maybe I just FORGET somethign new every day. Anyway I am on the right track. thanks.
Old Jun 30, 2021 | 03:09 PM
bmotojoe's Avatar
bmotojoe
That's why I asked if someone had a clearer photo of the switch connector part number.
You can learn a lot about a part by the part number...lol
To Wiper switch wiring
