Electrical gremlins
Old Oct 15, 2021 | 10:44 PM
Jd21476's Avatar
Jd21476
Default Electrical gremlins
I have twin electric fans and electric pop up headlights which earlier today were all working. Then suddenly my fans dont work and none of my lights work except my headlights but they dont pop up. I checked all fuses and relays and they are good but I am not getting any power at the fan relay so I have to chase wires. I hate electrical issues.
Old Oct 15, 2021 | 11:36 PM
Jd21476's Avatar
Jd21476
So running a test light, I get connections at all fuses except the second from the bottom on the right. It says directional signal/backup which makes sense but I get power on the right side, not the left although it doesnt look blown. Im going to pull it and check
Old Oct 16, 2021 | 11:56 AM
Jd21476's Avatar
Jd21476
So my electric headlights and twin electric fans were pulling power from the keyed hot for the backup lights under the hood and even though it did not look like it, the fuse was blown. I moved the power wire for the fans to the heater fuse in the fuse box since I do not have a heater and this fuse is not used. The original fuse was a 10A but I upped it to a 25A because the 10A blew immediately. I think this will be fine since I am only running the fans so in essence this is now my fuse specifically for my fans and not for my heater so I'm not overpowering a breaker. Does this sound right?
Old Oct 16, 2021 | 12:06 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
wire gauge is the reason, mainly, for fuses.
as long as the wires from the fuse can handle 25 amps
Old Oct 16, 2021 | 12:19 PM
Jd21476's Avatar
Jd21476
Thats a good point that I did not think about. Well the wire that I am running from the fuse box to the fans is a 10GA which should easily handle the 25A and since Im not running a heater there shouldn’t be any power running along the other wires.
Old Oct 16, 2021 | 09:02 PM
wwiiavfan's Avatar
wwiiavfan
From your description it sounds like you just discovered why most folks run electric fans and other high-draw accessories off of relays.
I suspect you will keep chasing this until you relay up.
Old Oct 16, 2021 | 10:25 PM
Jd21476's Avatar
Jd21476
Im actually running relays on both my fans and electric headlights
Old Oct 17, 2021 | 10:27 AM
Bikespace's Avatar
Bikespace
But where are the relays getting their power?
I have a sub-panel in the engine compartment, with a fused connection to the starter. Fan relays connect to that, and there are extra slots for the eventual electric headlight conversion (and the headlights themselves).
Old Oct 17, 2021 | 10:44 AM
Jd21476's Avatar
Jd21476
Can you send me a picture of what your sub panel or set up looks like? The relays are what the problem is because they are pulling alot of power.
My headlights are spliced in to the backup lights under the hood to pull keyed hot power and the fans were as well but it blew the fuse. I then pulled the dan relay off of that and I currently have it run to the heater fuse in the circuit breaker panel.
Old Oct 17, 2021 | 11:15 AM
Bikespace's Avatar
Bikespace
It's a big mess right now, attached to a non-AC fan/heater cover with a massive hole in it. But I followed @Richard454's wiring diagram, including the MRBF fuses.
In the C3 I used this Blue Sea Systems fuse block, and made my own 4 AWG cable. It has enough circuits that both fan relays can get their own fuse, with 6 circuits left over for headlights. The wires come out on one side. I've done similar installs with slightly different components in other vehicles. Depending on where you mount it, this Blue Sea fuse block may also be a good choice, with or without a common ground connection.
I'd look through this thread for inspiration and much better photos than my project car.
https://www.corvetteforum.com/forums...r-upgrade.html
To Electrical gremlins
