Shorten steering column
I’ve been looking into this for a while but does anyone know how to take 2-3” out of the steering column? Is it possible?
its a ‘71, non tilt (would prefer tilt)
It’s way too close to me. Ideally i’d like the existing column, just shorter.
I know flaming river etc sell shorter columns but I’m not sure they would fit like factory.
I’m in Northern Ireland. Anything I can use here saves the expensive of importing.
We’re not exactly falling over Vette columns here in Northern Ireland.
I know mine is good so would prefer to use it or get a tilt early column.
surely on disassembly it’s possible to take a few inches out of the case and the same from the shaft? Then get the shaft welded or resplined?
But will this mess up the gearbox lock etc? (I’ve got a TKO600 so I don’t need the gearbox lock anyway)
This is such an obvious flaw with the Vette interior I’m amazed no one has covered it?
It totally Ruins the driving experience with the wheel so close.
If someone sold this I’d be first in line-
Stock column design, stock key position etc
tilt/tele
just 2-3” shorter in length.
No gearbox lock
Seems no one sells that combo.😢
Over the years I have heard a number of people complain about getting in and out with the standard column.
But you are the first I personally have heard say the wheel is to close for driving. So, no I really don't think it's a big issue that the aftermarket needs to jump on.
A wheel with zero dish may just be the ticket for you.
I will warn you that the tilt feature on FR columns doesn't get you much upward tilt because few cars have a column as horizontal as ours. There is much more downward movement available. Full down tilt will actually points the steering wheel slightly downward. FR's lower dash mount is completely adjustable.
Good luck!
Good luck!
I’m not sure who they used to test the ergonomics of the Vette interior, someone with long legs, short arms, no knees and a short torso.
im Only 5’ 10 1/2” and I struggle with it.
With a shorter column and the seats lowered it’ll be good
I was at a car show last year and someone pointed at the steering column and laughed and Said something along the lines of “ look at the size of that” so yes it’s not just me!
One of the reasons I switched columns was because the PO had a 69+ interior in the car and I wanted to bring back some of the '68 only-ness to the car. Having recently completed the conversion from column key to dash pad key, you will need a '68 lower dash pad, and trim pieces which will run $400+ USD. The sheen and color are not likely to match what you need so you may need to dye it....assuming that your '71 color was even available in '68. The key switch is available since it is a generic GM part. The key switch bezels are available too. However, the female harness plug is not. The good news is that the ignition wiring on your existing column will reach the upper right position after you cut the your existing harness plug off, so you shouldn't need to splice in wires. I used spade connectors with anti-corrosion conductive grease and connected the wires individually. Also the '68 column was a smaller diameter than yours and the dash pad is made to that smaller diameter. The FR column is slightly larger than the stock '68 column, so you may need to do a small amount of trimming on the new dash pad. And finally, you will probably want to keep your direction signal and tilt stalks, because the billet aluminum ones that come with the FR column looked like s**t. The threads are identical so it's an easy swap.
Great info. As always there’s more to it than meets the eye....
I’m personally not bothered about having a horn or the gearbox lock.
My Vette is a ‘71 made to look like a ‘69. So it’s far from stock but you’d need to know Vette’s to know something is not all it seems.
I will message Flaming River now and see what they say.
