Door Panels
Old Jun 10, 2023 | 07:03 AM
crshields90's Avatar
crshields90
Navigator
Default Door Panels
Just got my first C3. 1973 Convertible. Based on the door panels and sport mirrors looks like the doors came off a 78-82.
If I wanted to put 73 door panels back on the car would I end up needing to change any of the internals of the door in order to go back to the correct style of door panels?
Old Jun 10, 2023 | 07:56 AM
crshields90
Navigator
Also does anyone know if the older style chrome mirrors mount to the same hole pattern as the sport mirrors?
I cant seem to find new sport mirrors for sale anywhere.
Old Jun 10, 2023 | 08:07 AM
gbvette62's Avatar
gbvette62
Yes. The latch mechanism, lock rods, inside lock and release mechanism all changed in 78, as did the manner in which the door panels mount and the arm rests attach. The type of inside release, where it mounts and how it works is all different on 78 up doors.
70-75 convertible doors were unique. The top rear of the door, above the latch assembly had a recess in it that contained a chrome plated alignment pin, that matted to a round, brass lined receiver at the top of the lock pillar. Without the extra rigidity that the coupe T-bar provided, the convertible bodies can sag in the middle (for lack of a better description), which is why GM added the alignment pins and receivers to the convertible doors. Good convertible doors aren't easy to come by anymore, but you really should consider finding a pair of convertible doors, instead of trying to convert your 78-82 doors to earlier mechanisms, and still not have the alignment pieces.
Sorry, I'm sure none of that is what you wanted to hear.
Welcome to the Forum!
Old Jun 10, 2023 | 08:22 AM
gbvette62's Avatar
gbvette62
No, the hole spacing is different, as is the way the mirrors mount.
The sport mirrors had studs on the bottom that go through the door and get nuts on them. The chrome mirror used a nut plate riveted inside the door skin. A mirror mount was attached to the door with two screws that screw into the nut plate, and the chrome mirror was attached to the mirror mount by an allen screw. Passenger side doors didn't have the nut plate in them, since the factory never installed chrome mirrors on the right. There was a dealer installed right hand mirror available that was attached using Well Nuts (a rubber captive nut sort of like a dry wall anchor) since there was no nut plate in the door.
The left hand sport mirror has been reproduced, but they're currently on back order with no estimated availability date right now. The right side mirror has never been repro'd, but replacement glass is available for both mirrors.
Old Jun 10, 2023 | 02:19 PM
crshields90
Navigator
Thanks this is exactly the information I needed. Car is an old restore so I just want to make sure I go at cleaning it up the right way.
To Door Panels
