82 C3 will not start
Old Aug 27, 2024 | 03:21 PM
rogerdavidstacey's Avatar
rogerdavidstacey
6th Gear
Default 82 C3 will not start
Hi everyone,
This is my first time writing so please excuse any errors.
I can't get 12 volts to the just installed new fuel pump. However I do get 8.5 volts which some people think is for the gauge on the dash. I even still get 8.5 volts with the 10 AMP fuel pump fuse removed. I have yet to remove the ground cable and clean it up however I can't find any corrosion. I also installed a new fuel pump relay hoping to cure the problem with no luck. I can hear the relay come to life when I turn the key to "on". The engine cranks over well. I just ordered shop manual. I also plan on removing all fuses to clean them. Thank you for your thoughts. Roger from Hamburg NY
Old Aug 27, 2024 | 08:34 PM
Fly skids up!'s Avatar
Fly skids up!
There's also a 20 amp fuse in the battery box for the fuel pump too.
Old Sep 2, 2024 | 08:36 AM
rogerdavidstacey
6th Gear
What are the three items behind the passenger seat?
I am referring to the wall in the storage area behind the passenger seat.
Old Sep 2, 2024 | 11:11 AM
Fly skids up!
One is the power antenna relay. The other two I'm not 100% on but I think one is the rear defroster relay and the other is pulse wiper module.
Old Sep 2, 2024 | 09:18 PM
rogerdavidstacey
6th Gear
The passenger door is not opening at all. The driver's door is. However, both the power locks are not working at all. I checked the fuses. The GM shop manual page 2D-10 says the internal circuit breaker will reset after running the car 1 to 3 minutes, I tried the round key in both doors and the driver's door lock worked properly but the passenger side was unresponsive. I'm hoping the 1 to 3 minutes produces results. Any ideas?
To 82 C3 will not start
