Wilwood Brakes 6 Piston Direct Bolt on 65-82 Corvette Front Replacement Caliper Kit
#143
Former Vendor
St. Jude Donor '13
The D8-6 caliper is a direct bolt-on replacement for the factory original calipers on all 1965-82 Corvette's. Forged billet aluminum bodies, stainless steel pistons and competition style high-temperature seals put an end to the rust, bore pitting and seal failures that plague the OE caliper design. D8-4 calipers provide low-maintenance performance and a huge weight savings with high temperature reliability for the street and track. D8-6 calipers mount in the stock location over stock rotors, and use the original style OE D8 brake pads. Calipers can be used with any wheel that clears the OE calipers. The factory piston sizes were duplicated to maintain the original front to rear brake bias and use of the OE master cylinder. Kits contain DOT compliant stainless steel braided brake lines with BP-10 high friction pads.
http://www.xplosiveperformance.com/65-82-Corvette-D8-6-Front-Replacement-Caliper-Kit-Clear-Anodize_p_2266.html
http://www.xplosiveperformance.com/Brake-Kits_c_5672.html
ALSO AVAILABLE IN BLACK OR RED POWDERCOAT
#144
Former Vendor
St. Jude Donor '13
65-82 Corvette D8-4 by Wilwood Front Replacement Caliper Kit
Clear Anodize
Brand New Not Rebuilt
Clear Anodize
#146
Former Vendor
St. Jude Donor '13
Clear Anodize
http://www.xplosiveperformance.com/6...ze_p_2269.html
Clear Anodize
#148
Former Vendor
St. Jude Donor '13
Clear Anodize
Clear Anodize
#149
Former Vendor
St. Jude Donor '13
Clear Anodize
Clear Anodize
#150
Former Vendor
St. Jude Donor '13
#151
Former Vendor
St. Jude Donor '13
Clear Anodize
Clear Anodize
#152
Former Vendor
St. Jude Donor '13
Clear Anodize
Clear Anodize
#153
Former Vendor
St. Jude Donor '13
Clear Anodize
Clear Anodize
