replacement speakers???
My original speakers are toast, so I ordered a replacement set online from ZipCorvette. My question is this. My original speakers are marked 10 ohm on the back, and the replacements I received are reading at about 3.5 ohms. Is this going to pose a potential disaster for my OEM radio???
Anyone else have these installed with any positive/negative feedback??
~Rich
68 Vette 327/350HP
#'s match
72K original miles
~Rich
68 Vette 327/350HP
#'s match
72K original miles
Don't understand that your old ones are stamped 10, but new ones "read" at 3.5. Clarify?
What I meant by "read" was I hooked them up to a multimeter and the ohms were at 3.5. I'm assuming that these are supposed to be 4 ohm speakers.
Big Fish---Where can I get the Delco replacements? Do they fit in the kick panels without any clearance issues???
Thanks all for the quick replies.
~Rich
Try GM Parts Direct, I know they have the oval speakers, but I'm assuming your speakers are round?
Edit: The dash speakers are 4 X 6, kick panel speakers are maybe 4 X 10? You still need 10 ohm speakers unless you change to a modern radio
Just want to say that I have been reading the forum every day for a few hours each day and I love the community here! You guys are always willing to help out, and us new guys really appreciate it!!
I'll let you know what I find out in the morning.
~Rich
~Rich
68 Vette 327/350HP
#'s match
72K original miles
Verify with the vendor what they really are. You can't do it with a multimeter like you did.... I use a computer test setup to measure impedance.
Just a heads up.
-Matt
Just a heads up.
-Matt
As far as asking the vendor, Zip didn't have a clue as to what the impedence rating was. They did offer to return the speakers for me if I feel they wont work, but I dont want to end up on a wild goose chase trying to find correct speakers.
~Rich
You can
A. Play it at low levels only
B. Try to find the supplier of the speaker and verify the impedance
C. Opt for some known good replacements. 8 ohms probably won't hurt anything especially if you don't normally blast it.
D. If you are in northeast OH I could try and plot a curve for ya. Chances are vettefixr is right and they are 4 ohm speakers.
GM is the only source I know of anymore for 10 ohm speakers (radio shack doesn't offer 8 ohm car speakers anymore). Every GM speaker I've seen is clearly stamped w/ the ohm rating. If your new ones from Zip aren't marked "ACDelco" or "GM" and don't say "10 ohms" - they are almost certainly not 10 ohms. Probably 4 ohms but an outside chance they are 8 ohms.
You can get 'em at any GM dealer or a variety of online sources. I just bought a pair for around $25 ea from a guy (small Corvette parts dealer) I mail order all my GM parts from for my Corvette - email me and I'll put you in touch if interested (he accepts CCs) or go to your local GM dealer or whatever.
I'm contemplating building a custom pair of speakers for a mid C3 w/ the dual DS-501 transistor stereo amp. The 662 factory 'upgrade' speakers are about as good as it gets for drop-in replacements, they are the correct 10 ohm speakers and all of that. But while way better than the originals - still not an ultimate hi fi speaker even for a vintage 68-76 amp. (FYI the later amps especially 74-76 are I think a lot better than earlier amps).
As you probably know these mount under the dash facing up and focusing on the windshield glass. THeir baskets are open and explosed to the dash and ultimatley footwells below...
As you know nice separate drivers exist including 8 ohms. Again for an original amp I was thinking of putting together a 4X6 plate w/ cutouts for say a 4" driver and a 1" tweeter and a crossover. THoughts...? Any idea how much better this might be over the ACDelco 4X6 10 ohm given an amp that puts out a couple few watts on a good day?
The other question applies equally to ACDelco 4X6s or a 'custom' speaker and that is enclosures for the face up dash speakers open to the bottom... I was toying w/ the idea of a 4X6 foam baffle and some polyfill in there. No it's not a serious rigid enclosure but perhaps it would be better than an 'open' speaker...? Or is it worth the trouble?
Crutchfield offers XTC Foam baffles in 4X6 w/ either a 3.5" depth or shallow 2.5" depth. The guages on the passenger side probably force the 2.5" depth.
And given a baffle like this - worth cutting a small hole in bottom or not?
I know there are other options like kick panels or rears but right now for this particular project only the original dash mount 4X6 location is an option. And the speaker needs to be at least 8 ohms. Those are THE constraints for this project.
thanks!
Years ago I put a set of separates in my '77 Corvette with an aftermarket radio. I think I had 4" mid ranges in the kick panels and tweeters on a plate in the dash locations with the cross-overs stuffed behind the radio. Sound was pretty good that way...but that likely won't work easily with a stock '68 radio...
4 Ohms= Car Audio
Thanks for the help.
~Rich
