What years of C3 doors are interchangeable??
i picked up another 80 vette last month. its not bad shape hit on drivers side. all the doors i seem to find forsale are late 60 early 70s.
will 68-77 doors work on 78-82 vette???
anyone selling a decent door?
thanks
john
thanks
john
according to my interchange book
1979 & 1980 driver door part #14011827 passenger #14011828 were used in these year vettes,
note(s) interchange with striker on 1979 models, except when swapping to older models; salvage yard dealers say 1981 & 1982 will fit.
1981 & 1982 driver door part # 14018939 passenger #14018940
I don't know which years interchange exactly, but I know now that
someone put 79-up doors on my 75 coupe.
I never would have known, but I went to change the lock
cylinders.
they are different for later C3s. So, maybe the latching
mechanism is, too.
Also, the window crank was in a different location.
Up til then, I wondered why the door panel had an "extra" hole.
I would say yo uhave no troubles putting a 69-up door on.
Just remember that the door panels and hardware may not
fit perfectly.
IMO - upgrade to the early style door panels.
cylinders.
mechanism is, too.
fit perfectly.
All coupe doors physically interchange-however: 68 is by itself due to the lock/pushbutton being together. 69-77 are 1 style door panel and really 69-72 have no internal crash bar, while 73-77 do, but they interchange redily. Then 78-82 are another style door panel. It is not easy to make early doors work on a late car unless you use corresponding door panels. Verts all interchange, but 68 is by itself, and the 73-75 has the crash bar.
71VETTEWI (03-05-2021)
ok, thanks guys. new question:
I'm asking becuase i have a good deal on this 69 door,
Regardless, my 80 door panel has got to go on this new door. my newest consideration is, the car has power windows, this eliminated the window crank hole from the door panel. the next problem is will the lock and door handle (inside of the car) from the 69 door work with my 80 door panel?
worst case scenario, i take this 1969 door, line up my 1980 door on the operating table next to it. cut out the entire interior metal skin from the 80, and mig it into the 69 door. now all my door panel parts are the same, everything lines up, change over the metal rod linkages, and budda bing budda boom- bobs my uncle.
anyone ever pull this off?
Exactly what shape is your 80 door in, what's still good? Re-skining may be alot easier if your 80 structure is still good. Otherwise I'd use the 69 and transplant only the parts really needed. But note: door mechanisms are a PITA to get at.
Info that doesn't matter: The window glass on 81-82 (not sure about 80) is thiner than the earlier years.
going to look at this 69 door today.
Hey, Did you check on the parts for sale section, a member there is parting out an '82, his forum name is SCALF, give it a look, ya never know. Peace,,,Moosie
Ebay has several door nobody bidding can probably get the 80 door for around 100 $ plus shipping , then just transfer your hardware. I think you might have another problem if your door is "loaded up" with putty. The car could have been hit and the nose was not repaired or replaced properly and they built up the door to match. I hope not.
oh yea, and i bought the 69 drivers door last night for $40... Canadian which is like $4 to you guys.... and anyways, the guy was also selling a 79 (passenger) door... so i compared the 2 doors, the skins obvisouly appear identical, but the inside, the only real difference i noticed was where the door handle hole is located and the door lock hole... I think it will be reasonable to get it to work.
Originally Posted by Bloodvette
Funny you ask, becuase the car HAS been "hit and the nose was not repaired or replaced properly and they built up the door to match." The whole drivers side fender is 3/4" out of place. I never got too far inspecting it... will have another look this weekend. it will be a big job.
I have a pair of Vette doors and windows 250 plus shipping
